Up to 20% off select tools
Dell Inspiron M5010 RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
76
All Time:
899
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Dell Inspiron M5010 RAM Replacement, Battery: step 1, image 1 of 2 Dell Inspiron M5010 RAM Replacement, Battery: step 1, image 2 of 2
      • Make sure laptop is powered off before removing the battery.
      • Slide both arrow tabs towards the outer edge of the computer to release the battery.
      • Battery is not shown.
      Ask FixBot
    1. Dell Inspiron M5010 RAM Replacement, RAM: step 2, image 1 of 2 Dell Inspiron M5010 RAM Replacement, RAM: step 2, image 2 of 2
      • Using the Phillips #000 screwdriver, loosen the screw holding in the back cover.
      • Then, lift up the back cover to remove it.
      Ask FixBot
    2. Dell Inspiron M5010 RAM Replacement: step 3, image 1 of 3 Dell Inspiron M5010 RAM Replacement: step 3, image 2 of 3 Dell Inspiron M5010 RAM Replacement: step 3, image 3 of 3
      • Snap open the top memory clips and remove the memory drive they hold in.
      Ask FixBot
    3. Dell Inspiron M5010 RAM Replacement: step 4, image 1 of 3 Dell Inspiron M5010 RAM Replacement: step 4, image 2 of 3 Dell Inspiron M5010 RAM Replacement: step 4, image 3 of 3
      • Snap open the bottom memory clips and remove the memory drive they hold in.
      Ask FixBot
    4. Dell Inspiron M5010 RAM Replacement: step 5, image 1 of 1
      • The laptop computer should look like this once both memory cards are removed.
      Ask FixBot
Author
with
April Poucher
1,164 Reputation
10 Guides authored
Clemson, Team 1-5, Benson Fall 2014 Member of Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 76
All Time: 899
