Dell Inspiron M5010 Camera Replacement
    1. Dell Inspiron M5010 Camera Replacement, Battery: step 1, image 1 of 2 Dell Inspiron M5010 Camera Replacement, Battery: step 1, image 2 of 2
      • Make sure laptop is powered off before removing the battery.
      • Slide both arrow tabs towards the outer edge of the computer to release the battery.
      • Battery is not shown.
      Ask FixBot
    1. Dell Inspiron M5010 Camera Replacement, Remove keyboard retaining screw: step 2, image 1 of 1
      • Remove Keyboard retaining screw from bottom of laptop.
      Ask FixBot
    2. Dell Inspiron M5010 Camera Replacement: step 3, image 1 of 3 Dell Inspiron M5010 Camera Replacement: step 3, image 2 of 3 Dell Inspiron M5010 Camera Replacement: step 3, image 3 of 3
      • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
      • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
      Ask FixBot
    3. Dell Inspiron M5010 Camera Replacement: step 4, image 1 of 1
      • Lift the keyboard up slightly and push forward in order to release bottom tabs.
      Ask FixBot
    4. Dell Inspiron M5010 Camera Replacement: step 5, image 1 of 1
      • Pull the black tab up and then pull left on keyboard plug to release keyboard.
      Ask FixBot
    1. Dell Inspiron M5010 Camera Replacement, Palm Rest: step 6, image 1 of 1
      • Flip the laptop, so the bottom of the laptop is facing up.
      • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
      Ask FixBot
    2. Dell Inspiron M5010 Camera Replacement: step 7, image 1 of 2 Dell Inspiron M5010 Camera Replacement: step 7, image 2 of 2
      • Flip the laptop back over, so that the top of the laptop is facing up.
      • Open the laptop.
      • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
      Ask FixBot
    3. Dell Inspiron M5010 Camera Replacement: step 8, image 1 of 1
      • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
      Ask FixBot
    4. Dell Inspiron M5010 Camera Replacement: step 9, image 1 of 3 Dell Inspiron M5010 Camera Replacement: step 9, image 2 of 3 Dell Inspiron M5010 Camera Replacement: step 9, image 3 of 3
      • Carefully unsnap and remove the palm rest.
      • Place your fingers inside the large circle in the lower right corner to get a good grip.
      Ask FixBot
    1. Dell Inspiron M5010 Camera Replacement, LCD Screen: step 10, image 1 of 1
      • Flip the laptop over to its backside.
      • Using the Phillips #000 Screwdriver remove the six indicated 6.0mm Phillips #000 screws.
      Ask FixBot
    2. Dell Inspiron M5010 Camera Replacement: step 11, image 1 of 1
      • Flip the laptop over to its front side and open the laptop.
      • Remove the four 6.0mm Phillips #000 screws holding the screen to the base of the laptop using a Phillips #000 Screwdriver.
      Ask FixBot
    3. Dell Inspiron M5010 Camera Replacement: step 12, image 1 of 2 Dell Inspiron M5010 Camera Replacement: step 12, image 2 of 2
      • Pull up both the black and white chords to completely detach the screen.
      Ask FixBot
    4. Dell Inspiron M5010 Camera Replacement: step 13, image 1 of 2 Dell Inspiron M5010 Camera Replacement: step 13, image 2 of 2
      • Lift the screen from the base of the laptop.
      Ask FixBot
    5. Dell Inspiron M5010 Camera Replacement: step 14, image 1 of 2 Dell Inspiron M5010 Camera Replacement: step 14, image 2 of 2
      • Use a spudger to separate and remove the plastic frame on the front of the screen.
      Ask FixBot
    6. Dell Inspiron M5010 Camera Replacement: step 15, image 1 of 2 Dell Inspiron M5010 Camera Replacement: step 15, image 2 of 2
      • Use a Phillips #000 Screwdriver to remove the 8 6.0mm Phillips #000 screws marked in the image.
      Ask FixBot
    7. Dell Inspiron M5010 Camera Replacement: step 16, image 1 of 1
      • Lift LCD screen from the plastic frame.
      Ask FixBot
    8. Dell Inspiron M5010 Camera Replacement: step 17, image 1 of 3 Dell Inspiron M5010 Camera Replacement: step 17, image 2 of 3 Dell Inspiron M5010 Camera Replacement: step 17, image 3 of 3
      • Flip LCD screen over to view the backside.
      • Lift brown tab in the middle of the screen and pull to remove the entire piece.
      Ask FixBot
    9. Dell Inspiron M5010 Camera Replacement: step 18, image 1 of 2 Dell Inspiron M5010 Camera Replacement: step 18, image 2 of 2
      • Use a Phillips #000 Screwdriver to remove the four screws indicated (two on each side).
      • Pull metal frames away from LCD screen.
      • The metal frame on each side is pulled away separately, so make sure to make note of which side each one came from.
      Ask FixBot
    1. Dell Inspiron M5010 Camera Replacement, Camera: step 19, image 1 of 2 Dell Inspiron M5010 Camera Replacement, Camera: step 19, image 2 of 2
      • Using a Phillips #000 Screwdriver, remove the indicated 6.0 mm screw on the left side of the camera.
      • Pull the tab and release the ribbon on the right side of the camera.
      • Pull the camera away from the plastic frame.
      Ask FixBot
April Poucher
1,164 Reputation
10 Guides authored
Clemson, Team 1-5, Benson Fall 2014 Member of Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 91
All Time: 570
