Up to 20% off select tools
Dell Inspiron E1705 RAM Replacement
Views: 9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
92
All Time:
8,964
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Very easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Parts
Tools
Introduction
Go to step 1 ↓
Please read the troubleshooting section before using this repair guide to take apart your computer. Many problems can be resolved without taking the computer apart.
It is important to remove the battery before following these instructions. It will ensure no electrical discharge to occur. If you are unsure at all about how to remove the battery please refer to the battery repair guide for this item.
    1. Dell Inspiron E1705 RAM Replacement, Battery: step 1, image 1 of 1
      • Make sure that the computer is turned off and is disconnected from external power source.
      • Turn it upside down and locate the battery release switch.
      Ask FixBot
    2. Dell Inspiron E1705 RAM Replacement: step 2, image 1 of 2 Dell Inspiron E1705 RAM Replacement: step 2, image 2 of 2
      • While holding the switch in the open position, lift out the battery.
      • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
      Ask FixBot
    1. Dell Inspiron E1705 RAM Replacement, RAM: step 3, image 1 of 2 Dell Inspiron E1705 RAM Replacement, RAM: step 3, image 2 of 2
      • Turn the computer over, screen closed, so that the underside is showing
      • Locate the two screws as shown and remove them.
      • Use a small phillips head screwdriver
      Ask FixBot
    2. Dell Inspiron E1705 RAM Replacement: step 4, image 1 of 3 Dell Inspiron E1705 RAM Replacement: step 4, image 2 of 3 Dell Inspiron E1705 RAM Replacement: step 4, image 3 of 3
      • Remove plastic cover carefully
      • There will be two RAM sticks as shown
      • Using your fingers, pull the sides apart that are holding the RAM in place. This will release the RAM.
      Ask FixBot
    3. Dell Inspiron E1705 RAM Replacement: step 5, image 1 of 1
      • Carefully remove old/damaged RAM sticks and replace with new ones.
      Ask FixBot
5 other people completed this guide.
Author
with
Evan Fairchild
625 Reputation
4 Guides authored
Cal Poly, Team 22-5, Maness Fall 2010 Member of Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Members
108 Guides authored
1 Guide Comment
If upgrading RAM, a black DOS based screen will show stating "the amount of RAM in system has changed", wait 1minute and the computer will beep and prompt for F1 (boot normally) or F2 (run system setup utility). Pressing F2 and waiting some time will allow the computer to reconfigure and then boot into Windows normally.
bejtommywy - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 92
All Time: 8,964
