Dell Inspiron E1705 Optical Drive Replacement
    1. Dell Inspiron E1705 Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Make sure that the computer is turned off and is disconnected from external power source.
      • Turn it upside down and locate the battery release switch.
      Ask FixBot
    2. Dell Inspiron E1705 Optical Drive Replacement: step 2, image 1 of 2 Dell Inspiron E1705 Optical Drive Replacement: step 2, image 2 of 2
      • While holding the switch in the open position, lift out the battery.
      • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
      Ask FixBot
    1. Dell Inspiron E1705 Optical Drive Replacement, Optical Drive: step 3, image 1 of 1
      • Locate and remove the screw shown
      • It is labeled with a lock symbol
      Ask FixBot
    2. Dell Inspiron E1705 Optical Drive Replacement: step 4, image 1 of 2 Dell Inspiron E1705 Optical Drive Replacement: step 4, image 2 of 2
      • Use the screwdriver to gently push the optical drive out
      Ask FixBot
3 other people completed this guide.
Evan Fairchild
625 Reputation
4 Guides authored
Cal Poly, Team 22-5, Maness Fall 2010 Member of Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 113
All Time: 4,491
