Dell Inspiron E1705 Battery Replacement
Views: 5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
102
All Time:
4,975
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide is very important for other guides, as the battery must be removed before dealing with electronic connections within the computers encasement.
    1. Dell Inspiron E1705 Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure that the computer is turned off and is disconnected from external power source.
      • Turn it upside down and locate the battery release switch.
      Ask FixBot
    2. Dell Inspiron E1705 Battery Replacement: step 2, image 1 of 2 Dell Inspiron E1705 Battery Replacement: step 2, image 2 of 2
      • While holding the switch in the open position, lift out the battery.
      • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
      Ask FixBot
To replace your battery, follow these instructions in reverse order.
5 other people completed this guide.
Malik Shahbal
471 Reputation
5 Guides authored
Cal Poly, Team 22-5, Maness Fall 2010 Member of Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Members
108 Guides authored
1 Guide Comment
I think it would be complete if we knew where to buy it as well.
Nobody would read up on changing a battery if he didn’t need one, so you might as well tell him where to get it.
I think that makes sense. However thank you for your effort.
kjanmunkedal - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 102
All Time: 4,975
