Dell Inspiron E1505 RAM Replacement
    1. Dell Inspiron E1505 RAM Replacement, Battery: step 1, image 1 of 1
      • Before any work can be done ensure that the laptop is powered off.
      • Use either the power button on the computer or issue a shutdown from the operating system.
      • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
      Ask FixBot
    2. Dell Inspiron E1505 RAM Replacement: step 2, image 1 of 1
      • Locate the battery release switch on the bottom of the laptop.
      • Once located slide the switch into the unlock position.
      Ask FixBot
    3. Dell Inspiron E1505 RAM Replacement: step 3, image 1 of 1
      • Locate the “lip” on the laptop to lift the battery outside of the compartment.
      • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
      Ask FixBot
    4. Dell Inspiron E1505 RAM Replacement: step 4, image 1 of 1
      • Once the new battery has been acquired take the battery and place it in the empty battery slot.
      • Slide the switch into the lock position to secure the new battery.
      Ask FixBot
    1. Dell Inspiron E1505 RAM Replacement, RAM: step 5, image 1 of 1
      • On the back of the laptop there is a compartment for the RAM for easy access.
      • It is located right above the switch for the battery and has two phillips head screws as well as a sticker for the laptops product key.
      • Unscrew the two screws with a screwdriver and lift the backplate up to unveil the RAM.
      Ask FixBot
    2. Dell Inspiron E1505 RAM Replacement: step 6, image 1 of 1
      • There are two metal tabs on each of the sticks of RAM.
      • Press each of the tabs outward and the RAM stick should slide up.
      • Gently pull the stick of RAM out and get the product number to get replacement RAM.
      • Do this for both of the sticks of RAM.
      Ask FixBot
    3. Dell Inspiron E1505 RAM Replacement: step 7, image 1 of 1
      • Inserting new RAM: Line up the RAM by making sure the slot on the RAM stick lines up with the slot on the laptop.
      • Insert it at slight angle while it lined up.
      • Gently press the stick of RAM down until the two metal tabs snap it back in. Repeat this as necessary.
      Ask FixBot
2 other people completed this guide.
Anthony Toscano
323 Reputation
3 Guides authored
UMass Dartmouth, Team 6-7, Martin Fall 2016 Member of UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 104
All Time: 1,034
