Dell Inspiron E1505 Optical Drive Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
101
All Time:
1,360
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
    1. Dell Inspiron E1505 Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Before any work can be done ensure that the laptop is powered off.
      • Use either the power button on the computer or issue a shutdown from the operating system.
      • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
      Ask FixBot
    2. Dell Inspiron E1505 Optical Drive Replacement: step 2, image 1 of 1
      • Locate the battery release switch on the bottom of the laptop.
      • Once located slide the switch into the unlock position.
      Ask FixBot
    3. Dell Inspiron E1505 Optical Drive Replacement: step 3, image 1 of 1
      • Locate the “lip” on the laptop to lift the battery outside of the compartment.
      • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
      Ask FixBot
    4. Dell Inspiron E1505 Optical Drive Replacement: step 4, image 1 of 1
      • Once the new battery has been acquired take the battery and place it in the empty battery slot.
      • Slide the switch into the lock position to secure the new battery.
      Ask FixBot
    1. Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: step 5, image 1 of 3 Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: step 5, image 2 of 3 Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: step 5, image 3 of 3
      • Remove the back panel: Use the screwdriver to remove the screws on the back panel.
      • Lift the back panel off the laptop to expose the interior of the laptop.
      • Locate the hard drive.
      Ask FixBot
    2. Dell Inspiron E1505 Optical Drive Replacement: step 6, image 1 of 1
      • Remove the current optical drive.
      • Look at the model number and order the replacement if needed.
      • Insert the new optical drive in.
      Ask FixBot
Anthony Toscano
323 Reputation
3 Guides authored
UMass Dartmouth, Team 6-7, Martin Fall 2016 Member of UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Members
48 Guides authored
2 Guide Comments
@oldturkey03 This guide is showing how to remove the ODD, not the HDD. I was wondering if I should change it. The guide is also incorrect. Only one screw is necessary to remove the ODD. I suppose I should make another and archive this...
George A. - Reply Share
@pccheese it's a student guide so leave it alone. Do not archive anything on this. Go ahead and create your guide and then post that as an alternative. I would give the composer of this guide the courtesy and kindly let them know.
oldturkey03 - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 101
All Time: 1,360
