Dell Inspiron E1505 Modem Replacement
    1. Dell Inspiron E1505 Modem Replacement, Battery: step 1, image 1 of 1
      • Before any work can be done ensure that the laptop is powered off.
      • Use either the power button on the computer or issue a shutdown from the operating system.
      • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
      Ask FixBot
    2. Dell Inspiron E1505 Modem Replacement: step 2, image 1 of 1
      • Locate the battery release switch on the bottom of the laptop.
      • Once located slide the switch into the unlock position.
      Ask FixBot
    3. Dell Inspiron E1505 Modem Replacement: step 3, image 1 of 1
      • Locate the “lip” on the laptop to lift the battery outside of the compartment.
      • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
      Ask FixBot
    4. Dell Inspiron E1505 Modem Replacement: step 4, image 1 of 1
      • Once the new battery has been acquired take the battery and place it in the empty battery slot.
      • Slide the switch into the lock position to secure the new battery.
      Ask FixBot
    1. Dell Inspiron E1505 Modem Replacement, Back Door removal: step 5, image 1 of 1
      • On the back of the laptop there is a compartment for the modem for easy access.
      • It is located right above the switch for the battery and has two phillips head screws as well as a sticker for the laptops product key.
      • Unscrew the two screws with a screwdriver and lift the backplate up to unveil the Modem.
      Ask FixBot
    2. Dell Inspiron E1505 Modem Replacement: step 6, image 1 of 1
      • There are two metal tabs on each of the sticks of the modem.
      • Press each of the tabs outward and the modem stick should slide up.
      • Gently pull the stick of phone modem out and get the product number to get replacement modem.
      • Do this for both of the sticks of phone modem.
      Ask FixBot
    3. Dell Inspiron E1505 Modem Replacement, Inserting a new modem: step 7, image 1 of 1
      • Installing a new modem: Line up the new modem by making sure the slot where the modem is installed lines up with the position of the connector on the new modem.
      • Push the modem down. Make sure to do this evenly so the modem makes a good connection.
      • Repeat this procedure until the modem is secure.
      Ask FixBot
Onelis Ivette Sanchez
168 Reputation
1 Guide authored
UMass Dartmouth, Team 6-7, Martin Fall 2016 Member of UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Members
48 Guides authored
1 Guide Comment
That is not the wireless card. That is the phone modem. The wireless card is a mini PCI-e card located directly under the backspace key.
George A. - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 104
All Time: 1,079
