Dell Inspiron E1505 Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
103
All Time:
1,281
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the battery of a laptop is a rater straight forward process that takes a small amount of time. This is guide will show you how to replace your laptop’s old battery with a new one.
    1. Dell Inspiron E1505 Battery Replacement, Battery: step 1, image 1 of 1
      • Before any work can be done ensure that the laptop is powered off.
      • Use either the power button on the computer or issue a shutdown from the operating system.
      • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
      Ask FixBot
    2. Dell Inspiron E1505 Battery Replacement: step 2, image 1 of 1
      • Locate the battery release switch on the bottom of the laptop.
      • Once located slide the switch into the unlock position.
      Ask FixBot
    3. Dell Inspiron E1505 Battery Replacement: step 3, image 1 of 1
      • Locate the “lip” on the laptop to lift the battery outside of the compartment.
      • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
      Ask FixBot
    4. Dell Inspiron E1505 Battery Replacement: step 4, image 1 of 1
      • Once the new battery has been acquired take the battery and place it in the empty battery slot.
      • Slide the switch into the lock position to secure the new battery.
      Ask FixBot
Anthony Toscano
323 Reputation
3 Guides authored
UMass Dartmouth, Team 6-7, Martin Fall 2016 Member of UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 103
All Time: 1,281
