Dell Inspiron E1405 RAM Replacement
    1. Dell Inspiron E1405 RAM Replacement, Battery: step 1, image 1 of 1
      • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
      • Flip the laptop over.
      • Locate the battery release switch on the bottom of the laptop.
      Ask FixBot
    2. Dell Inspiron E1405 RAM Replacement: step 2, image 1 of 3 Dell Inspiron E1405 RAM Replacement: step 2, image 2 of 3 Dell Inspiron E1405 RAM Replacement: step 2, image 3 of 3
      • Slide the battery release switch away from the lock symbol until you hear the battery click.
      • Slide the battery towards the back of the laptop until it comes free.
      Ask FixBot
    1. Dell Inspiron E1405 RAM Replacement, RAM: step 3, image 1 of 3 Dell Inspiron E1405 RAM Replacement, RAM: step 3, image 2 of 3 Dell Inspiron E1405 RAM Replacement, RAM: step 3, image 3 of 3
      • Locate the RAM access door.
      • Remove the two 5.5mm screws securing the RAM access door with a #00 Phillips screwdriver.
      Ask FixBot
    2. Dell Inspiron E1405 RAM Replacement: step 4, image 1 of 1
      • Using your fingers, open and remove the access door from the laptop, exposing the RAM underneath.
      Ask FixBot
    3. Dell Inspiron E1405 RAM Replacement: step 5, image 1 of 3 Dell Inspiron E1405 RAM Replacement: step 5, image 2 of 3 Dell Inspiron E1405 RAM Replacement: step 5, image 3 of 3
      • To access the RAM, push out the latches outward on the left and right of the RAM.
      • To remove the memory card, pull it out of the tray with the latches still stretched out.
      Ask FixBot
Sarah Neal Secrest
597 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 104
All Time: 972
