Dell Inspiron E1405 LCD Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
92
All Time:
949
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide will help you replace the LCD screen in a Dell Inspiron 1305 laptop.
Tools
    1. Dell Inspiron E1405 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
      • Flip the laptop over.
      • Locate the battery release switch on the bottom of the laptop.
      Ask FixBot
    2. Dell Inspiron E1405 LCD Screen Replacement: step 2, image 1 of 3 Dell Inspiron E1405 LCD Screen Replacement: step 2, image 2 of 3 Dell Inspiron E1405 LCD Screen Replacement: step 2, image 3 of 3
      • Slide the battery release switch away from the lock symbol until you hear the battery click.
      • Slide the battery towards the back of the laptop until it comes free.
      Ask FixBot
    1. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: step 3, image 1 of 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: step 3, image 2 of 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: step 3, image 3 of 3
      • Use your fingers or a spudger to remove the six small rubber covers off the display assembly.
      • Remove the six 5.7 mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    2. Dell Inspiron E1405 LCD Screen Replacement: step 4, image 1 of 1
      • Use your fingers to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
      • Remove the front display bezel when it comes free.
      Ask FixBot
    3. Dell Inspiron E1405 LCD Screen Replacement: step 5, image 1 of 3 Dell Inspiron E1405 LCD Screen Replacement: step 5, image 2 of 3 Dell Inspiron E1405 LCD Screen Replacement: step 5, image 3 of 3
      • Remove the three 3.6 mm screws using a Phillips #00 screwdriver on both sides of the display.
      • Remove the LCD screen from the display assembly.
      Ask FixBot
    4. Dell Inspiron E1405 LCD Screen Replacement: step 6, image 1 of 2 Dell Inspiron E1405 LCD Screen Replacement: step 6, image 2 of 2
      • Unplug the VGA cable by pushing the two metal sides towards the middle of the strip.
      • Gently pull the VGA cable away to release the strip.
      Ask FixBot
    5. Dell Inspiron E1405 LCD Screen Replacement: step 7, image 1 of 2 Dell Inspiron E1405 LCD Screen Replacement: step 7, image 2 of 2
      • Remove the next connection by pressing the two metal sides towards the middle. Then gently pull up the ribbon.
      Ask FixBot
Sarah Neal Secrest
597 Reputation
5 Guides authored
1 Guide Comment
I need complete body *Dell INSPIRON E1405 .
St Master Fun - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 92
All Time: 949
