Up to 20% off select tools
Dell Inspiron Duo RAM Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
96
All Time:
3,123
Comments: 8
6 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove the RAM from the laptop and replace it with a new 2GB RAM stick.
    1. Dell Inspiron Duo RAM Replacement, Front Cover: step 1, image 1 of 2 Dell Inspiron Duo RAM Replacement, Front Cover: step 1, image 2 of 2
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Flip your device over so the bottom panel is facing up.
      • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
      Ask FixBot
    2. Dell Inspiron Duo RAM Replacement: step 2, image 1 of 2 Dell Inspiron Duo RAM Replacement: step 2, image 2 of 2
      • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
      • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
      Ask FixBot
    3. Dell Inspiron Duo RAM Replacement: step 3, image 1 of 2 Dell Inspiron Duo RAM Replacement: step 3, image 2 of 2
      • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
      Ask FixBot
    1. Dell Inspiron Duo RAM Replacement, RAM: step 4, image 1 of 1
      • With the cover removed, locate the 2GB RAM stick. It will be in the upper-middle portion of the device. The RAM stick is the flat blue rectangular object that has four black squares running along it vertically (for convenience, the RAM stick has been outlined in red in the photo).
      Ask FixBot
    2. Dell Inspiron Duo RAM Replacement: step 5, image 1 of 2 Dell Inspiron Duo RAM Replacement: step 5, image 2 of 2
      • There are two white spring levers on either side of the RAM. Pull them out gently to release the RAM. This will cause the RAM to stick up at a forty-five degree angle.
      • With the RAM at a forty-five degree angle, gently pull it straight out of the device.
      Ask FixBot
    3. Dell Inspiron Duo RAM Replacement: step 6, image 1 of 2 Dell Inspiron Duo RAM Replacement: step 6, image 2 of 2
      • With the RAM stick flipped up, carefully lift it out of the slot.
      Ask FixBot
2 other people completed this guide.
Author
with
Steven Luther
778 Reputation
3 Guides authored
UW Tacoma, Team 1-1, Liner SU 2015 Member of UW Tacoma, Team 1-1, Liner SU 2015
UWT-LINER-SU15S1G1
3 Members
48 Guides authored
2 Guide Comments
Good effort, but incomplete. Laptop parts can be very easily damaged, so removing all the screws is important.
Chiel Kersten - Reply Share
Good evening!!!
Is it possible to install a M.2 or NVME SSD in this netbook model?
Greetings and blessings from Venezuela!!!!
Edwin Guerra AvendaƱo - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 96
All Time: 3,123
