Dell Inspiron Duo Hard Drive Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
107
All Time:
5,800
Comments: 8
6 comments on steps, 2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The Hard Drive is one of the main components of any computer. Replacing it isn't extremely difficult, but important nonetheless. In this guide, we'll walk you through replacing the hard drive in the Dell Inspiron Duo, step by step, making it easy for anyone to accomplish.
Tools
    1. Dell Inspiron Duo Hard Drive Replacement, Front Cover: step 1, image 1 of 2 Dell Inspiron Duo Hard Drive Replacement, Front Cover: step 1, image 2 of 2
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Flip your device over so the bottom panel is facing up.
      • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
      Ask FixBot
    2. Dell Inspiron Duo Hard Drive Replacement: step 2, image 1 of 2 Dell Inspiron Duo Hard Drive Replacement: step 2, image 2 of 2
      • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
      • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
      Ask FixBot
    3. Dell Inspiron Duo Hard Drive Replacement: step 3, image 1 of 2 Dell Inspiron Duo Hard Drive Replacement: step 3, image 2 of 2
      • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
      Ask FixBot
    1. Dell Inspiron Duo Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
      • With the laptop open, locate the hard drive. It will be on the left side of the laptop, the side with the power button.
      • Remove the two screws on the left side of the hard drive enclosure.
      Ask FixBot
    2. Dell Inspiron Duo Hard Drive Replacement: step 5, image 1 of 1
      • With the screws removed, the hard drive will slide from the left to right, disconnecting it from the hard drive port.
      • Lift the hard drive and hard drive enclosure out out of laptop.
      Ask FixBot
    3. Dell Inspiron Duo Hard Drive Replacement: step 6, image 1 of 2 Dell Inspiron Duo Hard Drive Replacement: step 6, image 2 of 2
      • With the hard drive and the metal case that encloses the hard drive removed from the laptop, you will see two screws on either side of the metal case. Remove these screws and lift the hard drive out of the metal casing.
      • Set the hard drive to the side and slide a new hard drive to the metal casing, ensuring that the white label is on top.
      Ask FixBot
7 other people completed this guide.
Steven Luther
778 Reputation
3 Guides authored
UW Tacoma, Team 1-1, Liner SU 2015 Member of UW Tacoma, Team 1-1, Liner SU 2015
UWT-LINER-SU15S1G1
3 Members
48 Guides authored
2 Guide Comments
This guide leaves out some critical information:
In step 1 there are two additional screws under the removable panel at the bottom of the picture.
In step 2 it should be noted that the keyboard and trackpad connectors have tiny clamps that should be dealt with carefully. If lost your Duo will no longer function unless you can somehow find replacements.
In step 3 there are four additional screws not mentioned that must be removed before the top panel can be removed. I nearly damaged my Duo irreparably by first unsnapping the sides with a flat spudger and then attempting to lift the panel off. Once the four unmentioned screws are removed the panel comes off easily.
Following this guide to the letter will result in either confusion or damage to your Duo.
Aaron Nicholson - Reply Share
Many thanks for the instructions. Very help together with comments from Aaron. Also YouTube video on disassembling the Duo. As Aaron said be careful with the three small connectors. I broke the black plastic on one of them. The trick is to lift the white plastic catch and cable then comes out.
Abaid Mughal - Reply Share
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 107
All Time: 5,800
