Introduction
Replacing a motherboard is a complex repair that is rarely necessary. If your Dell Inspiron B130 is experiencing issues such as failing to power on, freezing, or unexpected shutdowns, these problems are often caused by other hardware components like the RAM, hard drive, or power supply. Before proceeding with this guide, confirm that the motherboard is the actual cause of failure and not another replaceable component.
Remove the battery by flipping the two switches under the battery and pulling it out
Remove the 8mm screw
Use the plastic opening tool to push out the disk drive.
Pull the disk drive out with the opposite hand.
This particular computer is missing its hard drive.
Remove the two screws.
Remove the plastic cover by lifting from the groove as indicated.
Remove the hard drive from the computer by lifting up and out.
Put down the computer and open up the screen.
There is a long piece of plastic underneath the screen that you will have to remove.
Remove the three 6mm screws.
Lift the plastic cover off to reveal the RAM and the Wireless.
Use a Phillips #0 screwdriver to remove the twelve 8mm screws from the bottom of the laptop.
Lift and remove the entire cover/frame from the top of the motherboard. Gently pull up to detach it without using excessive force
Remove the motherboard by pulling it upward and sliding it to the right. Be careful not to damage any remaining connectors or components. If the motherboard feels stuck, double-check that all screws and cables have been disconnected.
