Dell Inspiron B130 Keyboard Replacement
    1. Dell Inspiron B130 Keyboard Replacement, Battery: step 1, image 1 of 3 Dell Inspiron B130 Keyboard Replacement, Battery: step 1, image 2 of 3 Dell Inspiron B130 Keyboard Replacement, Battery: step 1, image 3 of 3
      • First, make sure your computer is turned off.
      • Remove the battery by flipping the two switches under the battery and pulling it out
      Ask FixBot
    2. Dell Inspiron B130 Keyboard Replacement: step 2, image 1 of 3 Dell Inspiron B130 Keyboard Replacement: step 2, image 2 of 3 Dell Inspiron B130 Keyboard Replacement: step 2, image 3 of 3
      • Push the tab from the battery, downwards to unlock the battery.
      • The tab should be in the position next to the unlocked indicator.
      Ask FixBot
    3. Dell Inspiron B130 Keyboard Replacement: step 3, image 1 of 3 Dell Inspiron B130 Keyboard Replacement: step 3, image 2 of 3 Dell Inspiron B130 Keyboard Replacement: step 3, image 3 of 3
      • Now, push the other tab (the one right under the battery) from right to left.
      • Now the battery will be loose; lift the battery up and out of the computer.
      Ask FixBot
    1. Dell Inspiron B130 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Put down the computer and open up the screen.
      • There is a long piece of plastic underneath the screen that you will have to remove.
      Ask FixBot
    2. Dell Inspiron B130 Keyboard Replacement: step 5, image 1 of 3 Dell Inspiron B130 Keyboard Replacement: step 5, image 2 of 3 Dell Inspiron B130 Keyboard Replacement: step 5, image 3 of 3
      • When you pry the plastic plate off, be careful and pry gently so you do not crack the plastic.
      • Insert the plastic opening tool into the little slot.
      • Lift up gently and remove the plastic cover.
      Ask FixBot
    3. Dell Inspiron B130 Keyboard Replacement: step 6, image 1 of 1
      • Remove the two 4mm screws at the top of the keyboard.
      • The keyboard is now loose but don't pull it out just yet. It is still connected underneath. Be gentle when lifting keyboard so you do not damage this connection.
      Ask FixBot
    4. Dell Inspiron B130 Keyboard Replacement: step 7, image 1 of 2 Dell Inspiron B130 Keyboard Replacement: step 7, image 2 of 2
      • Lift keyboard up slightly and you will see the keyboard connection.
      • This black tab has to be lifted up to remove the keyboard.
      • Put your finger underneath the tab and pull back gently as indicated.
      • You can now remove the keyboard.
      Ask FixBot
Patrick McNeil
955 Reputation
8 Guides authored
UMass Dartmouth, Team 1-8, Catania Fall 2016 Member of UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 98
All Time: 635
