Dell Inspiron B130 Disk Drive Replacement
    1. Dell Inspiron B130 Disk Drive Replacement, Battery: step 1, image 1 of 3 Dell Inspiron B130 Disk Drive Replacement, Battery: step 1, image 2 of 3 Dell Inspiron B130 Disk Drive Replacement, Battery: step 1, image 3 of 3
      • First, make sure your computer is turned off.
      • Remove the battery by flipping the two switches under the battery and pulling it out
      Ask FixBot
    2. Dell Inspiron B130 Disk Drive Replacement: step 2, image 1 of 3 Dell Inspiron B130 Disk Drive Replacement: step 2, image 2 of 3 Dell Inspiron B130 Disk Drive Replacement: step 2, image 3 of 3
      • Push the tab from the battery, downwards to unlock the battery.
      • The tab should be in the position next to the unlocked indicator.
      Ask FixBot
    3. Dell Inspiron B130 Disk Drive Replacement: step 3, image 1 of 3 Dell Inspiron B130 Disk Drive Replacement: step 3, image 2 of 3 Dell Inspiron B130 Disk Drive Replacement: step 3, image 3 of 3
      • Now, push the other tab (the one right under the battery) from right to left.
      • Now the battery will be loose; lift the battery up and out of the computer.
      Ask FixBot
    1. Dell Inspiron B130 Disk Drive Replacement, Disk Drive: step 4, image 1 of 3 Dell Inspiron B130 Disk Drive Replacement, Disk Drive: step 4, image 2 of 3 Dell Inspiron B130 Disk Drive Replacement, Disk Drive: step 4, image 3 of 3
      • Remove the 8mm screw
      • Use the plastic opening tool to push out the disk drive.
      • Pull the disk drive out with the opposite hand.
      Ask FixBot
    2. Dell Inspiron B130 Disk Drive Replacement: step 5, image 1 of 1
      • You can now remove the disk drive.
      Ask FixBot
Patrick McNeil
955 Reputation
8 Guides authored
UMass Dartmouth, Team 1-8, Catania Fall 2016 Member of UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 97
All Time: 531
