Dell Inspiron 9300 Video Card Replacement
    1. Dell Inspiron 9300 Video Card Replacement, Prerequisite Only: step 1, image 1 of 2 Dell Inspiron 9300 Video Card Replacement, Prerequisite Only: step 1, image 2 of 2
      • Remove the battery prior to working on any internal components.
      • Remove the twelve 6mm Phillips screws from the bottom of the case.
      • Remove the battery before working on internal components to ensure a safe working environment.
      Ask FixBot
    2. Dell Inspiron 9300 Video Card Replacement: step 2, image 1 of 1
      • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
      • Start on the right hand side, where there is a notch in the bezel for easiest removal.
      Ask FixBot
    3. Dell Inspiron 9300 Video Card Replacement: step 3, image 1 of 3 Dell Inspiron 9300 Video Card Replacement: step 3, image 2 of 3 Dell Inspiron 9300 Video Card Replacement: step 3, image 3 of 3
      • Remove the two 5mm Phillips screws retaining the keyboard.
      • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
      • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
      Ask FixBot
    4. Dell Inspiron 9300 Video Card Replacement: step 4, image 1 of 2 Dell Inspiron 9300 Video Card Replacement: step 4, image 2 of 2
      • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
      • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
      • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
      Ask FixBot
    5. Dell Inspiron 9300 Video Card Replacement: step 5, image 1 of 2 Dell Inspiron 9300 Video Card Replacement: step 5, image 2 of 2
      • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
      • Gently pry the CMOS battery out of its retaining clip using a spudger.
      Ask FixBot
    6. Dell Inspiron 9300 Video Card Replacement: step 6, image 1 of 2 Dell Inspiron 9300 Video Card Replacement: step 6, image 2 of 2
      • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
      • Remove the trackpad ribbon cable from the motherboard using a spudger.
      Ask FixBot
    7. Dell Inspiron 9300 Video Card Replacement: step 7, image 1 of 2 Dell Inspiron 9300 Video Card Replacement: step 7, image 2 of 2
      • Pull up and away on the track pad to expose the internal components below.
      Ask FixBot
    1. Dell Inspiron 9300 Video Card Replacement, Video Card: step 8, image 1 of 1
      • Loosen the four 5mm Phillips screws holding the video card and heatsink in place
      • The screws are held in place with retainer clips and are not fully removable
      Ask FixBot
    2. Dell Inspiron 9300 Video Card Replacement: step 9, image 1 of 1
      • Firmly pull up to unseat the video card from the motherboard.
      Ask FixBot
Steven Faulkner
490 Reputation
4 Guides authored
USF Tampa, Team 16-6, Eyestone Fall 2016 Member of USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Members
132 Guides authored
1 Guide Comment
This works only up to the point of pull up and away on the trackpad. The trackpad won't pull up.
cobrachoppergirl - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 102
All Time: 1,420
