Dell Inspiron 9300 Keyboard Replacement
    1. Dell Inspiron 9300 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Use the spudger to remove the top cover plate to expose the screws for the keyboard.
      • Be sure not to break the clips holding it in. Once the side has been lifted, gently lift the plate with your hand to remove it completely.
      Ask FixBot
    2. Dell Inspiron 9300 Keyboard Replacement: step 2, image 1 of 1
      • Remove the two 5mm Phillips screws holding the keyboard in place.
      Ask FixBot
    3. Dell Inspiron 9300 Keyboard Replacement: step 3, image 1 of 1
      • Pull the keyboard away from the laptop.
      • Be careful when pulling the keyboard not to damage the connecting ribbon underneath.
      Ask FixBot
    4. Dell Inspiron 9300 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 9300 Keyboard Replacement: step 4, image 2 of 2
      • Gently pull up on the blue tab to disconnect the keyboard.
      • Pull the keyboard up and away to safely remove the keyboard.
      Ask FixBot
Ady Alhamra
149 Reputation
1 Guide authored
USF Tampa, Team 16-6, Eyestone Fall 2016 Member of USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 95
All Time: 958
