Dell Inspiron 9100 Optical Drive/Accessory Device Replacement
    1. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: step 1, image 3 of 3
      • Unplug the laptop from the power adapter and turn the power off.
      • Failure to unplug laptop before proceeding could result in risk of electric shock!
      Ask FixBot
    2. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: step 2, image 1 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: step 2, image 2 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: step 2, image 3 of 3
      • Slide the battery-lock tab and hold.
      • Flip the battery away from the chassis to remove it.
      Ask FixBot
    1. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: step 3, image 1 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: step 3, image 2 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: step 3, image 3 of 3
      • Press the tab on the outside face of the optical drive to release a handle.
      • Pull the handle to eject the optical drive unit from the slot, and slide it out.
      Ask FixBot
charlierefvem
854 Reputation
7 Guides authored
Cal Poly, Team 13-2, Forte Winter 2011 Member of Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 112
All Time: 2,745
