Dell Inspiron 9100 Fan 2 Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
89
All Time:
2,844
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This guide requires a Phillips #00 screwdriver
Tools
    1. Dell Inspiron 9100 Fan 2 Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 9100 Fan 2 Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 9100 Fan 2 Replacement, Battery: step 1, image 3 of 3
      • Unplug the laptop from the power adapter and turn the power off.
      • Failure to unplug laptop before proceeding could result in risk of electric shock!
      Ask FixBot
    2. Dell Inspiron 9100 Fan 2 Replacement: step 2, image 1 of 3 Dell Inspiron 9100 Fan 2 Replacement: step 2, image 2 of 3 Dell Inspiron 9100 Fan 2 Replacement: step 2, image 3 of 3
      • Slide the battery-lock tab and hold.
      • Flip the battery away from the chassis to remove it.
      Ask FixBot
    1. Dell Inspiron 9100 Fan 2 Replacement, Fan 2: step 3, image 1 of 2 Dell Inspiron 9100 Fan 2 Replacement, Fan 2: step 3, image 2 of 2
      • Undo the two screws on the fan cover labeled "F2"
      • These screws will remain in the panel
      • Remove cover plate.
      Ask FixBot
    2. Dell Inspiron 9100 Fan 2 Replacement: step 4, image 1 of 1
      • Remove the single 6mm screw holding the fan in place.
      Ask FixBot
    3. Dell Inspiron 9100 Fan 2 Replacement: step 5, image 1 of 2 Dell Inspiron 9100 Fan 2 Replacement: step 5, image 2 of 2
      • Flip the handle up.
      • Use the handle to pull the fan away directly up, away from case.
      Ask FixBot
charlierefvem
854 Reputation
7 Guides authored
Cal Poly, Team 13-2, Forte Winter 2011 Member of Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 89
All Time: 2,844
