Dell Inspiron 910 Touchpad Buttons Replacement
    1. Dell Inspiron 910 Touchpad Buttons Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop so the battery is facing upwards.
      • Push the battery release tabs toward the center of the device.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron 910 Touchpad Buttons Replacement, Keyboard: step 2, image 1 of 1
      • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
      Ask FixBot
    2. Dell Inspiron 910 Touchpad Buttons Replacement: step 3, image 1 of 1
      • Lift up the keyboard using your fingers or a plastic opening tool.
      • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
      • Disconnect the cable by sliding the connector ears outward.
      Ask FixBot
    1. Dell Inspiron 910 Touchpad Buttons Replacement, Touchpad Buttons: step 4, image 1 of 1
      • Remove the seven Phillips #00 screws that hold the metal component to the frame
      • Detach the two ribbon cables on either side of the silver panel
      • Be careful to not tear the ribbon cables hidden behind the panel
      • Gently lift the silver panel from the laptop using the plastic opening tool
      • Set the laptop aside
      • depending on your model, there could still be some hidden screws on the bottom of the case of the mini that hold the palm-rest in place
      Ask FixBot
    2. Dell Inspiron 910 Touchpad Buttons Replacement: step 5, image 1 of 1
      • Flip the silver panel over
      • Remove the four screws that connect the buttons to the panel using the Phillips #00 Screwdriver
      Ask FixBot
    3. Dell Inspiron 910 Touchpad Buttons Replacement: step 6, image 1 of 1
      • Remove the covers from the panel
      • Remove the buttons from the panel
      • Release the mouse button by flipping the center connector tab up
      Ask FixBot
Kyle Beekman
144 Reputation
6 Guides authored
Cal Poly, Team 14-10, Forte Spring 2012 Member of Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 105
All Time: 2,774
