Dell Inspiron 910 Speaker Replacement
    1. Dell Inspiron 910 Speaker Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop so the battery is facing upwards.
      • Push the battery release tabs toward the center of the device.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron 910 Speaker Replacement, Keyboard: step 2, image 1 of 1
      • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
      Ask FixBot
    2. Dell Inspiron 910 Speaker Replacement: step 3, image 1 of 1
      • Lift up the keyboard using your fingers or a plastic opening tool.
      • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
      • Disconnect the cable by sliding the connector ears outward.
      Ask FixBot
    1. Dell Inspiron 910 Speaker Replacement, Speaker: step 4, image 1 of 1
      • After removing the keyboard, use the plastic opening tool or other form of leverage to remove the rest of the silver casing.
      • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
      Ask FixBot
    2. Dell Inspiron 910 Speaker Replacement: step 5, image 1 of 1
      • Use a plastic tool to carefully pry the silver portion front of the top away from the colored portion.
      Ask FixBot
    3. Dell Inspiron 910 Speaker Replacement: step 6, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the two small screws at the bottom corners of the speaker assembly.
      • Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
      Ask FixBot
    4. Dell Inspiron 910 Speaker Replacement: step 7, image 1 of 1
      • Slide out the cables connected to the speakers and the base below the keyboard.
      • Remove the speakers from the laptop.
      Ask FixBot
3 other people completed this guide.
Kyle Beekman
144 Reputation
6 Guides authored
Cal Poly, Team 14-10, Forte Spring 2012 Member of Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 1,959
