Dell Inspiron 910 Solid-State Drive (SSD) Replacement
    1. Dell Inspiron 910 Solid-State Drive (SSD) Replacement, Remove screws from SSD: step 1, image 1 of 1
      • "CAUTION"If you remove the solid-state drive from the computer when the drive is hot, do not touch the solid-state drive
      • Remove the two screws that secure the solid-state drive.
      • Lift the solid-state drive out of its system board connector.
      Ask FixBot
      • Insert the solid-state drive into the slot at a 45-degree angle.
      • Press the solid-state drive down and replace the two screws that secure the drive.
      • Replace the module cover
      • Slide the battery into the battery bay, until it clicks into place and slide the battery-lock latch towards the lock position.
      Ask FixBot
      • Make sure to replace all screws and ensure that there are no stray bolts.
      Ask FixBot
Devyn Johnson
232 Reputation
2 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 111
All Time: 1,268
