Up to 20% off select tools
Dell Inspiron 910 Screen Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
87
All Time:
3,244
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
The screen is one of the most crucial components of a laptop. Without a proper screen, a laptop can be rendered useless. In the event of your Dell Inspiron 910 laptop’s screen display is not functioning as intended, this guide will assist in removing the screen with step by step instruction. Possible issues that would require screen replacement include a cracked screen, dead pixels, backlight failure, or one that has gone completely blank. Before using this guide, make sure the laptop is powered off completely to prevent any further damage and the necessary tools are accessible.
    1. Dell Inspiron 910 Screen Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop so the battery is facing upwards.
      • Push the battery release tabs toward the center of the device.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron 910 Screen Replacement, Screen: step 2, image 1 of 1
      • Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
      Ask FixBot
    2. Dell Inspiron 910 Screen Replacement: step 3, image 1 of 1
      • Unscrew the two screws using a Phillips #00 screwdriver from the metal casing that retains the screen.
      Ask FixBot
    3. Dell Inspiron 910 Screen Replacement: step 4, image 1 of 1
      • Pull down the laptop's back, keeping the screen upright, held in place by two metal strips going along its sides.
      • Unscrew the 4 screws from the two strips.
      • While unscrewing the second side, make sure to hold the screen so that it doesn't fall when the screws are removed.
      Ask FixBot
    4. Dell Inspiron 910 Screen Replacement: step 5, image 1 of 1
      • Gently lay the screen down, being careful not to damage the ribbon connector.
      Ask FixBot
    5. Dell Inspiron 910 Screen Replacement: step 6, image 1 of 1
      • Disconnect the cord connecting the screen to the rest of the laptop. The cable will be attached to the screen using tape, so it can be safely removed. The actual cord connection is at the circuit board.
      Ask FixBot
    6. Dell Inspiron 910 Screen Replacement: step 7, image 1 of 1
      • Pull the screen out. Congratulations! You have removed the screen.
      Ask FixBot
2 other people completed this guide.
Author
with
Kyle Beekman
144 Reputation
6 Guides authored
Cal Poly, Team 14-10, Forte Spring 2012 Member of Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 87
All Time: 3,244
