Dell Inspiron 8600 Power Button Replacement
    1. Dell Inspiron 8600 Power Button Replacement, Battery: step 1, image 1 of 1
      • Remove the battery from the bottom left of the laptop as shown.
      • Remove the battery before operating on the computer to avoid electrocution.
      Ask FixBot
    1. Dell Inspiron 8600 Power Button Replacement, Power Button: step 2, image 1 of 3 Dell Inspiron 8600 Power Button Replacement, Power Button: step 2, image 2 of 3 Dell Inspiron 8600 Power Button Replacement, Power Button: step 2, image 3 of 3
      • Locate the small opening at the upper left of the top blue panel which houses the power button.
      • Use a spudger to lift up and remove the blue panel.
      • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
      Ask FixBot
    2. Dell Inspiron 8600 Power Button Replacement: step 3, image 1 of 1
      • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
      • You should now be able to completely remove the hinge cover.
      Ask FixBot
3 other people completed this guide.
Brian Murphy
368 Reputation
4 Guides authored
Cal Poly, Team 18-22, Garner Spring 2011 Member of Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 96
All Time: 4,702
