Dell Inspiron 8600 Keyboard Replacement
    1. Dell Inspiron 8600 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Remove the battery from the bottom left of the laptop as shown.
      • Remove the battery before operating on the computer to avoid electrocution.
      Ask FixBot
    1. Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: step 2, image 1 of 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: step 2, image 2 of 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: step 2, image 3 of 3
      • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
      • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
      • Be careful of the wire attached to the underside of the hinge cover.
      Ask FixBot
    2. Dell Inspiron 8600 Keyboard Replacement: step 3, image 1 of 1
      • Pull the small black tab on the right hand side of the laptop.
      • You have now removed the hinge cover.
      Ask FixBot
    1. Dell Inspiron 8600 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: step 4, image 3 of 3
      • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
      • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
      • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
      • The keyboard should be easily removable at this point.
      Ask FixBot
2 other people completed this guide.
Perry
251 Reputation
4 Guides authored
Cal Poly, Team 18-22, Garner Spring 2011 Member of Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Members
180 Guides authored
1 Guide Comment
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 106
All Time: 4,537
