Dell Inspiron 8600 Display Removal
    1. Dell Inspiron 8600 Display Removal, Battery: step 1, image 1 of 1
      • Remove the battery from the bottom left of the laptop as shown.
      • Remove the battery before operating on the computer to avoid electrocution.
      Ask FixBot
    1. Dell Inspiron 8600 Display Removal, Hinge Cover: step 2, image 1 of 3 Dell Inspiron 8600 Display Removal, Hinge Cover: step 2, image 2 of 3 Dell Inspiron 8600 Display Removal, Hinge Cover: step 2, image 3 of 3
      • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
      • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
      • Be careful of the wire attached to the underside of the hinge cover.
      Ask FixBot
    2. Dell Inspiron 8600 Display Removal: step 3, image 1 of 1
      • Pull the small black tab on the right hand side of the laptop.
      • You have now removed the hinge cover.
      Ask FixBot
    1. Dell Inspiron 8600 Display Removal, Display Module: step 4, image 1 of 2 Dell Inspiron 8600 Display Removal, Display Module: step 4, image 2 of 2
      • Flip the laptop over and remove the indicated screws.
      • Flip the laptop back over.
      • Find the two places where the display module is attached to the base of the computer.
      Ask FixBot
    2. Dell Inspiron 8600 Display Removal: step 5, image 1 of 1
      • Disconnect the video card from the display module by gently lifting upwards on the black tab.
      Ask FixBot
    3. Dell Inspiron 8600 Display Removal: step 6, image 1 of 2 Dell Inspiron 8600 Display Removal: step 6, image 2 of 2
      • Lift the display module directly upwards from the base of the computer.
      Ask FixBot
    4. Dell Inspiron 8600 Display Removal: step 7, image 1 of 1
      • Now remove the display module.
      Ask FixBot
2 other people completed this guide.
Victor
187 Reputation
1 Guide authored
Cal Poly, Team 18-22, Garner Spring 2011 Member of Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 108
All Time: 4,414
