Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement
    1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Battery: step 1, image 2 of 2
      • Make sure computer is off before you begin.
      • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
      • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
      Ask FixBot
    2. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 2, image 1 of 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 2, image 2 of 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 2, image 3 of 3
      • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
      • Lift off the bottom cover.
      • After the base cover is removed, your laptop should look similar as depicted in the images provided.
      Ask FixBot
    3. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 3, image 1 of 1
      • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
      Ask FixBot
    4. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 4, image 1 of 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 4, image 2 of 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 4, image 3 of 3
      • Using the pull tab, disconnect the battery cable from the system board.
      • Lift the battery out from the laptop case.
      Ask FixBot
    1. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Memory Modules: step 5, image 1 of 2 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement, Memory Modules: step 5, image 2 of 2
      • Peel back the mylar coverings on the RAM chips on the right side of the system board.
      Ask FixBot
    2. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 6, image 1 of 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 6, image 2 of 3 Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 6, image 3 of 3
      • Push outward on the two gray tabs on either side of the RAM module.
      • These tabs hold down the RAM modules, which should pop up when disengaged.
      • Gently pull the memory module out of its slot.
      • Be sure to only touch the edges of the RAM module, as the oil from your fingers can damage the components on the face.
      Ask FixBot
    3. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 7, image 1 of 1
      • With the new memory module, line up the notch on the memory with the tab on the module slot.
      • Insert the memory module at an angle.
      • Push down on the module until the locking tabs on either side click into place.
      • If there is no click, reinsert the module.
      Ask FixBot
    4. Dell Inspiron 7573 2-in-1 Memory Modules (RAM) Replacement: step 8, image 1 of 1
      • Repeat steps 5-7 for the other memory module.
      • In this laptop, one set of tabs was gray plastic and the other was metallic.
      • When pushing down on the memory modules, make sure you hear a click.
      Ask FixBot
Brady Kennedy
109 Reputation
1 Guide authored
Casper College, Team 1-2, Lareau Fall 2021 Member of Casper College, Team 1-2, Lareau Fall 2021
CASC-LAREAU-F21S1G2
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 67
All Time: 764
