Dell Inspiron 7568 Wifi Card Replacement
    1. Dell Inspiron 7568 Wifi Card Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Wifi Card Replacement, Battery: step 1, image 2 of 2
      • Remove the ten 7mm Phillips #1 screws on the bottom cover.
      • Remove the bottom cover.
      Ask FixBot
    2. Dell Inspiron 7568 Wifi Card Replacement: step 2, image 1 of 2 Dell Inspiron 7568 Wifi Card Replacement: step 2, image 2 of 2
      • Remove the four 3mm Phillips #1 screws holding the battery.
      • Unhinge the connector cable to the battery.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron 7568 Wifi Card Replacement, Hard-Drive: step 3, image 1 of 1
      • Remove the three 3mm Phillips #1 screws connecting the hard drive to the laptop.
      Ask FixBot
    2. Dell Inspiron 7568 Wifi Card Replacement: step 4, image 1 of 2 Dell Inspiron 7568 Wifi Card Replacement: step 4, image 2 of 2
      • Disconnect the highlighted SATA cable from the hard drive.
      Ask FixBot
    3. Dell Inspiron 7568 Wifi Card Replacement: step 5, image 1 of 1
      • Remove the four 3mm Phillips #1 screws of the hard drive. Both sides look identical.
      Ask FixBot
    4. Dell Inspiron 7568 Wifi Card Replacement: step 6, image 1 of 1
      • Remove the hard drive (right) from its frame (left).
      Ask FixBot
    1. Dell Inspiron 7568 Wifi Card Replacement, Wifi Card: step 7, image 1 of 2 Dell Inspiron 7568 Wifi Card Replacement, Wifi Card: step 7, image 2 of 2
      • Remove the wide-brimmed 3mm Phillips #1 screw connecting the Wifi Card.
      • Remove the Wifi Card.
      Ask FixBot
Elijah Basile
358 Reputation
4 Guides authored
IUPUI, Team S1-G4, Stella Fall 2019 Member of IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 32
All Time: 362
