Dell Inspiron 7568 Trackpad Replacement Guide
    1. Dell Inspiron 7568 Trackpad Replacement Guide, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Trackpad Replacement Guide, Battery: step 1, image 2 of 2
      • Remove the ten 7mm Phillips #1 screws on the bottom cover.
      • Remove the bottom cover.
      Ask FixBot
    2. Dell Inspiron 7568 Trackpad Replacement Guide: step 2, image 1 of 2 Dell Inspiron 7568 Trackpad Replacement Guide: step 2, image 2 of 2
      • Remove the four 3mm Phillips #1 screws holding the battery.
      • Unhinge the connector cable to the battery.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: step 3, image 1 of 2 Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: step 3, image 2 of 2
      • Unplug the speaker cable and remove the speakers
      Ask FixBot
    2. Dell Inspiron 7568 Trackpad Replacement Guide: step 4, image 1 of 2 Dell Inspiron 7568 Trackpad Replacement Guide: step 4, image 2 of 2
      • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) holding the touchpad bracket
      • Remove the touchpad bracket
      Ask FixBot
    3. Dell Inspiron 7568 Trackpad Replacement Guide: step 5, image 1 of 3 Dell Inspiron 7568 Trackpad Replacement Guide: step 5, image 2 of 3 Dell Inspiron 7568 Trackpad Replacement Guide: step 5, image 3 of 3
      • Use a nylon spudger to lift the ZIF connector tab. Gently pull the touchpad ribbon cable free.
      • Use a nylon spudger to lift the ZIF connector tab. Gently pull the keyboard daughter board ribbon cable free.
      Ask FixBot
    4. Dell Inspiron 7568 Trackpad Replacement Guide: step 6, image 1 of 3 Dell Inspiron 7568 Trackpad Replacement Guide: step 6, image 2 of 3 Dell Inspiron 7568 Trackpad Replacement Guide: step 6, image 3 of 3
      • Remove the touchpad foil using a spudger or other ESD safe blunt-tip tool.
      • Unscrew & remove the three 2mm wafer screws holding the touchpad.
      • Remove the touchpad.
      Ask FixBot
2 other people completed this guide.
Yash Samant
406 Reputation
3 Guides authored
USF Tampa, Team S2-G2, Lacy Spring 2017 Member of USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 99
All Time: 667
