Dell Inspiron 7568 Motherboard Replacement
    1. Dell Inspiron 7568 Motherboard Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Remove the ten 7mm Phillips #1 screws on the bottom cover.
      • Remove the bottom cover.
      Ask FixBot
    2. Dell Inspiron 7568 Motherboard Replacement: step 2, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement: step 2, image 2 of 2
      • Remove the four 3mm Phillips #1 screws holding the battery.
      • Unhinge the connector cable to the battery.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron 7568 Motherboard Replacement, RAM: step 3, image 1 of 1
      • Release the RAM by unhinging the connecting bars outward.
      Ask FixBot
    2. Dell Inspiron 7568 Motherboard Replacement: step 4, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement: step 4, image 2 of 2
      • Remove the RAM.
      Ask FixBot
    1. Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: step 5, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: step 5, image 2 of 2
      • Begin by unclipping the cable connecting the fan and the motherboard.
      • Gently separate the motherboard cable from the clamp at the bottom of the fan.
      • Remove the cable.
      Ask FixBot
    2. Dell Inspiron 7568 Motherboard Replacement: step 6, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement: step 6, image 2 of 2
      • Remove the two 3mm Phillips #1 screws that hold the fan into place.
      • Remove the fan.
      Ask FixBot
    1. Dell Inspiron 7568 Motherboard Replacement, Motherboard: step 7, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Remove six 3mm Phillips #1 screws to fully remove the motherboard.
      • Disconnect the various connection points from the motherboard to the laptop.
      • Remove the motherboard.
      Ask FixBot
Elijah Basile
358 Reputation
4 Guides authored
IUPUI, Team S1-G4, Stella Fall 2019 Member of IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 34
All Time: 574
