Dell Inspiron 600m LCD Replacement
    1. Dell Inspiron 600m LCD Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 600m LCD Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 600m LCD Replacement, Battery: step 1, image 3 of 3
      • Flip laptop upside down and locate the battery as shown in the images.
      • Push in the tab on the battery and lift up. The battery should detach very easily.
      Ask FixBot
    1. Dell Inspiron 600m LCD Replacement, LCD: step 2, image 1 of 2 Dell Inspiron 600m LCD Replacement, LCD: step 2, image 2 of 2
      • Using fingernails or a spudger, push any direction on the rubber dots to remove them from the plastic cover.
      • Underneath each rubber dot will be a screw. Remove these screws with the Phillips #00 screwdriver.
      Ask FixBot
    2. Dell Inspiron 600m LCD Replacement: step 3, image 1 of 2 Dell Inspiron 600m LCD Replacement: step 3, image 2 of 2
      • Use the IFixit Opening Tool to un-clip the plastic cover, detaching it from the rest of the screen.
      • There are clips about every inch around the right, left, and top of the plastic cover. Be sure that all of them are unclipped.
      Ask FixBot
    3. Dell Inspiron 600m LCD Replacement: step 4, image 1 of 1
      • Pull straight up on the cover to lift the cover off of the rest of the screen.
      • The bottom part of the plastic is a little sticky.
      Ask FixBot
    4. Dell Inspiron 600m LCD Replacement: step 5, image 1 of 1
      • Remove four screws (two on each side of the screen) with the Phillips #00 screwdriver.
      • The middle screw does not need to be removed.
      Ask FixBot
    5. Dell Inspiron 600m LCD Replacement: step 6, image 1 of 1
      • Gently lift the LCD panel off of the base.
      • The LCD is still attached to the computer. Do not pull too hard or you could break the cable.
      Ask FixBot
    6. Dell Inspiron 600m LCD Replacement: step 7, image 1 of 3 Dell Inspiron 600m LCD Replacement: step 7, image 2 of 3 Dell Inspiron 600m LCD Replacement: step 7, image 3 of 3
      • Flip the LCD panel over.
      • Do not touch on or near the back of the panel where it says "Don't Touch." LCD panels contain mercury which is hazardous to humans.
      • Remove the cable by squeezing each side of the connector and gently pulling straight out.
      Ask FixBot
    7. Dell Inspiron 600m LCD Replacement: step 8, image 1 of 3 Dell Inspiron 600m LCD Replacement: step 8, image 2 of 3 Dell Inspiron 600m LCD Replacement: step 8, image 3 of 3
      • Remove the cable at the base of the laptop by pulling up on the yellow tab attached to the cable.
      Ask FixBot
4 other people completed this guide.
Alex Klimaj
143 Reputation
1 Guide authored
Cal Poly, Team 10-40, Forte Spring 2011 Member of Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 105
All Time: 7,563
