Dell Inspiron 600m Keyboard Replacement
    1. Dell Inspiron 600m Keyboard Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 600m Keyboard Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 600m Keyboard Replacement, Battery: step 1, image 3 of 3
      • Flip laptop upside down and locate the battery as shown in the images.
      • Push in the tab on the battery and lift up. The battery should detach very easily.
      Ask FixBot
    1. Dell Inspiron 600m Keyboard Replacement, Keyboard: step 2, image 1 of 1
      • Orient laptop with the keyboard facing upward and the lid open.
      Ask FixBot
    2. Dell Inspiron 600m Keyboard Replacement: step 3, image 1 of 3 Dell Inspiron 600m Keyboard Replacement: step 3, image 2 of 3 Dell Inspiron 600m Keyboard Replacement: step 3, image 3 of 3
      • Caution the face plate is a fragile piece of plastic. Handle carefully.
      • Start in the upper right corner and work to the left when removing the face plate (includes power button and volume controls).
      • Use a flathead screwdriver (or anything flat and strong) to wedge underneath the face plate.
      • Carefully lift the screwdriver to remove the face plate.
      Ask FixBot
    3. Dell Inspiron 600m Keyboard Replacement: step 4, image 1 of 3 Dell Inspiron 600m Keyboard Replacement: step 4, image 2 of 3 Dell Inspiron 600m Keyboard Replacement: step 4, image 3 of 3
      • Use a the Phillips screwdriver to remove the two screws.
      Ask FixBot
    4. Dell Inspiron 600m Keyboard Replacement: step 5, image 1 of 1
      • Gently slide keyboard toward screen.
      • Lift keyboard carefully. It is attached by a ribbon cable.
      Ask FixBot
    5. Dell Inspiron 600m Keyboard Replacement: step 6, image 1 of 3 Dell Inspiron 600m Keyboard Replacement: step 6, image 2 of 3 Dell Inspiron 600m Keyboard Replacement: step 6, image 3 of 3
      • Pull upward on blue tab to disconnect keyboard.
      Ask FixBot
3 other people completed this guide.
Peter Hallsten
148 Reputation
1 Guide authored
Cal Poly, Team 10-40, Forte Spring 2011 Member of Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 101
All Time: 4,035
