Dell Inspiron 600m Hard Drive Replacement
Views: 19K
View statistics:
Past 24 Hours:
3
Past 7 Days:
33
Past 30 Days:
122
All Time:
18,531
Comments: 2
2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide is will show how to replace a faulty hard drive.
Tools
    1. Dell Inspiron 600m Hard Drive Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 600m Hard Drive Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 600m Hard Drive Replacement, Battery: step 1, image 3 of 3
      • Flip laptop upside down and locate the battery as shown in the images.
      • Push in the tab on the battery and lift up. The battery should detach very easily.
      Ask FixBot
    1. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: step 2, image 1 of 1
      • The hard drive is located here.
      Ask FixBot
    2. Dell Inspiron 600m Hard Drive Replacement: step 3, image 1 of 1
      • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
      Ask FixBot
    3. Dell Inspiron 600m Hard Drive Replacement: step 4, image 1 of 1
      • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
      Ask FixBot
7 other people completed this guide.
Todd
146 Reputation
1 Guide authored
Cal Poly, Team 10-40, Forte Spring 2011 Member of Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Members
72 Guides authored
2 Guide Comments
What size is the hard drive, you know, to buy a new one?
Ethan White - Reply Share
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - Reply Share
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 122
All Time: 18,531
