Up to 20% off select tools
Dell Inspiron 600M RAM Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
88
All Time:
4,684
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Before removing the RAM you will need to remove your battery.
    1. Dell Inspiron 600M RAM Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 600M RAM Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 600M RAM Replacement, Battery: step 1, image 3 of 3
      • Flip laptop upside down and locate the battery as shown in the images.
      • Push in the tab on the battery and lift up. The battery should detach very easily.
      Ask FixBot
    1. Dell Inspiron 600M RAM Replacement, RAM: step 2, image 1 of 3 Dell Inspiron 600M RAM Replacement, RAM: step 2, image 2 of 3 Dell Inspiron 600M RAM Replacement, RAM: step 2, image 3 of 3
      • Remove the single screw securing the RAM compartment and pull up to reveal the RAM.
      Ask FixBot
    2. Dell Inspiron 600M RAM Replacement: step 3, image 1 of 3 Dell Inspiron 600M RAM Replacement: step 3, image 2 of 3 Dell Inspiron 600M RAM Replacement: step 3, image 3 of 3
      • Push on the small white metal tabs on both sides of a module to unlock it.
      • The RAM should be stick out at approximately a 45 degree angle. Grasp the RAM by the sides and pull straight out to remove it.
      • If the RAM sticks slightly, wiggle it back and forth gently to loosen it.
      Ask FixBot
Author
with
Taylor Woods
113 Reputation
2 Guides authored
Cal Poly, Team 10-40, Forte Spring 2011 Member of Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 88
All Time: 4,684
