Up to 20% off select tools
Dell Inspiron 6000 Screen Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
88
All Time:
3,397
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacing the screen takes some time and effort, but requires few tools.
    1. Dell Inspiron 6000 Screen Replacement, Battery: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is unplugged before removing the battery.
      • Flip the laptop over, bottom-side up.
      Ask FixBot
    2. Dell Inspiron 6000 Screen Replacement: step 2, image 1 of 1
      • Push the switch next to the battery.
      • At the same time, lift the battery away from the laptop.
      Ask FixBot
    1. Dell Inspiron 6000 Screen Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 6000 Screen Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 6000 Screen Replacement, Keyboard: step 3, image 3 of 3
      • Place the laptop on flat surface.
      • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
      • Carefully take a spudger and separate part of the cover at the red circle.
      Ask FixBot
    2. Dell Inspiron 6000 Screen Replacement: step 4, image 1 of 2 Dell Inspiron 6000 Screen Replacement: step 4, image 2 of 2
      • Remove two 4 mm Philips #00 screws.
      Ask FixBot
    3. Dell Inspiron 6000 Screen Replacement: step 5, image 1 of 1
      • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
      Ask FixBot
    4. Dell Inspiron 6000 Screen Replacement: step 6, image 1 of 3 Dell Inspiron 6000 Screen Replacement: step 6, image 2 of 3 Dell Inspiron 6000 Screen Replacement: step 6, image 3 of 3
      • Gently pull the blue tab up until it comes away from computer.
      Ask FixBot
    1. Dell Inspiron 6000 Screen Replacement, Screen: step 7, image 1 of 1
      • Remove one 4mm Philips #00 screw to completely disengage blue tab.
      Ask FixBot
    2. Dell Inspiron 6000 Screen Replacement: step 8, image 1 of 1
      • Pull and disconnect the blue tab.
      Ask FixBot
    3. Dell Inspiron 6000 Screen Replacement: step 9, image 1 of 1
      • Disconnect the black and white wires.
      Ask FixBot
    4. Dell Inspiron 6000 Screen Replacement: step 10, image 1 of 1
      • Remove four 4mm Philips #00 screws at the hinges for the screen.
      Ask FixBot
    5. Dell Inspiron 6000 Screen Replacement: step 11, image 1 of 1
      • Separate the top panel of the laptop from the bottom panel.
      Ask FixBot
    6. Dell Inspiron 6000 Screen Replacement: step 12, image 1 of 2 Dell Inspiron 6000 Screen Replacement: step 12, image 2 of 2
      • Use the plastic opening tools to remove the six rubber screw covers in the corners.
      • Remove six 4 mm #00 Philips screws located in the corners.
      Ask FixBot
    7. Dell Inspiron 6000 Screen Replacement: step 13, image 1 of 2 Dell Inspiron 6000 Screen Replacement: step 13, image 2 of 2
      • Insert the plastic opening tools between the screen holders.
      • Go completely around the screen, separating the screen holders with the plastic opening tools.
      Ask FixBot
    8. Dell Inspiron 6000 Screen Replacement: step 14, image 1 of 2 Dell Inspiron 6000 Screen Replacement: step 14, image 2 of 2
      • Remove 12 4mm #00 Philips screws at the perimeter of the screen.
      Ask FixBot
    9. Dell Inspiron 6000 Screen Replacement: step 15, image 1 of 2 Dell Inspiron 6000 Screen Replacement: step 15, image 2 of 2
      • Gently lift the screen from the holder.
      • Do not touch the copper part of the bottom side of the screen.
      Ask FixBot
3 other people completed this guide.
Author
with
Jacob DeWar
563 Reputation
3 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2014 Member of USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 88
All Time: 3,397
