Up to 20% off select tools
Dell Inspiron 6000 Keyboard Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
97
All Time:
2,950
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Removing and replacing the keyboard requires some disassembly and time.
    1. Dell Inspiron 6000 Keyboard Replacement, Battery: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is unplugged before removing the battery.
      • Flip the laptop over, bottom-side up.
      Ask FixBot
    2. Dell Inspiron 6000 Keyboard Replacement: step 2, image 1 of 1
      • Push the switch next to the battery.
      • At the same time, lift the battery away from the laptop.
      Ask FixBot
    1. Dell Inspiron 6000 Keyboard Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Place the laptop on flat surface.
      • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
      • Carefully take a spudger and separate part of the cover at the red circle.
      Ask FixBot
    2. Dell Inspiron 6000 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 6000 Keyboard Replacement: step 4, image 2 of 2
      • Remove two 4 mm Philips #00 screws.
      Ask FixBot
    3. Dell Inspiron 6000 Keyboard Replacement: step 5, image 1 of 1
      • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
      Ask FixBot
    4. Dell Inspiron 6000 Keyboard Replacement: step 6, image 1 of 3 Dell Inspiron 6000 Keyboard Replacement: step 6, image 2 of 3 Dell Inspiron 6000 Keyboard Replacement: step 6, image 3 of 3
      • Gently pull the blue tab up until it comes away from computer.
      Ask FixBot
5 other people completed this guide.
Author
with
Jacob DeWar
563 Reputation
3 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2014 Member of USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Members
84 Guides authored
1 Guide Comment
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
John KAPA - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 97
All Time: 2,950
