Dell Inspiron 6000 Fan Replacement
    1. Dell Inspiron 6000 Fan Replacement, Battery: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is unplugged before removing the battery.
      • Flip the laptop over, bottom-side up.
      Ask FixBot
    2. Dell Inspiron 6000 Fan Replacement: step 2, image 1 of 1
      • Push the switch next to the battery.
      • At the same time, lift the battery away from the laptop.
      Ask FixBot
    1. Dell Inspiron 6000 Fan Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 6000 Fan Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 6000 Fan Replacement, Keyboard: step 3, image 3 of 3
      • Place the laptop on flat surface.
      • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
      • Carefully take a spudger and separate part of the cover at the red circle.
      Ask FixBot
    2. Dell Inspiron 6000 Fan Replacement: step 4, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 4, image 2 of 2
      • Remove two 4 mm Philips #00 screws.
      Ask FixBot
    3. Dell Inspiron 6000 Fan Replacement: step 5, image 1 of 1
      • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
      Ask FixBot
    4. Dell Inspiron 6000 Fan Replacement: step 6, image 1 of 3 Dell Inspiron 6000 Fan Replacement: step 6, image 2 of 3 Dell Inspiron 6000 Fan Replacement: step 6, image 3 of 3
      • Gently pull the blue tab up until it comes away from computer.
      Ask FixBot
    1. Dell Inspiron 6000 Fan Replacement, Fan: step 7, image 1 of 1
      • Unscrew the 4 mm Phillips #00 screw.
      • The screw will remain attached to the cord when fully removed.
      Ask FixBot
    2. Dell Inspiron 6000 Fan Replacement: step 8, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 8, image 2 of 2
      • Gently pull the blue tab to separate the screen connection from the laptop.
      • Gently pull and disconnect the white and black cords from the power source.
      Ask FixBot
    3. Dell Inspiron 6000 Fan Replacement: step 9, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 9, image 2 of 2
      • Remove four 4mm #00 Philips screws from the screen hinges.
      • Lift the screen away from the laptop.
      Ask FixBot
    4. Dell Inspiron 6000 Fan Replacement: step 10, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 10, image 2 of 2
      • Remove two 4 mm Philips #00 screws that connect top of laptop to base..
      Ask FixBot
    5. Dell Inspiron 6000 Fan Replacement: step 11, image 1 of 1
      • Flip laptop the over and remove thirteen 6mm Philips #00 screws.
      Ask FixBot
    6. Dell Inspiron 6000 Fan Replacement: step 12, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 12, image 2 of 2
      • Insert the plastic opening tool in between the back and front plates of the laptop
      Ask FixBot
    7. Dell Inspiron 6000 Fan Replacement: step 13, image 1 of 1
      Ask FixBot
    8. Dell Inspiron 6000 Fan Replacement: step 14, image 1 of 1
      • Remove the fan power cord
      Ask FixBot
    9. Dell Inspiron 6000 Fan Replacement: step 15, image 1 of 2 Dell Inspiron 6000 Fan Replacement: step 15, image 2 of 2
      • Using your hand, lift the fan from the laptop.
      Ask FixBot
5 other people completed this guide.
Jacob DeWar
563 Reputation
3 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2014 Member of USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 119
All Time: 2,917
