Dell Inspiron 6000 DVD/CD Drive Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
105
All Time:
2,472
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Removing the DVD/CD drive will help to replace a broken or damaged drive.
Tools
    1. Dell Inspiron 6000 DVD/CD Drive Replacement, Battery: step 1, image 1 of 1
      • To prevent injury, make sure the laptop is unplugged before removing the battery.
      • Flip the laptop over, bottom-side up.
      Ask FixBot
    2. Dell Inspiron 6000 DVD/CD Drive Replacement: step 2, image 1 of 1
      • Push the switch next to the battery.
      • At the same time, lift the battery away from the laptop.
      Ask FixBot
    1. Dell Inspiron 6000 DVD/CD Drive Replacement, Removing the DVD/CD Drive Screw: step 3, image 1 of 1
      • Remove one 4mm Philips #00 screw.
      Ask FixBot
    2. Dell Inspiron 6000 DVD/CD Drive Replacement, Inserting Paper Clip: step 4, image 1 of 1
      • Open the paperclip as seen here.
      • Insert the paper clip into small hole next to the eject button on the disk drive.
      Ask FixBot
    3. Dell Inspiron 6000 DVD/CD Drive Replacement, Popping Out the DVD/CD Drive: step 5, image 1 of 1
      • With slight pressure, push the paperclip into the laptop.
      • The disk drive will slowly "pop out" of the side of the laptop.
      Ask FixBot
    4. Dell Inspiron 6000 DVD/CD Drive Replacement, Completely removing the DVD/CD Drive: step 6, image 1 of 1
      • Using your hand, pull the disk drive out of the laptop.
      Ask FixBot
Kenneth Odum
569 Reputation
4 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2014 Member of USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 105
All Time: 2,472
