Dell Inspiron 5758 Touchpad Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
68
All Time:
1,059
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will show you how to replace the touchpad on the Dell Inspiron 5758.
Parts
Tools
    1. Dell Inspiron 5758 Touchpad Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
      Ask FixBot
    2. Dell Inspiron 5758 Touchpad Replacement: step 2, image 1 of 3 Dell Inspiron 5758 Touchpad Replacement: step 2, image 2 of 3 Dell Inspiron 5758 Touchpad Replacement: step 2, image 3 of 3
      • Slide the battery release switch towards the unlock icon.
      • You should hear a click.
      • Lift and pull the ejected battery to remove it.
      Ask FixBot
    1. Dell Inspiron 5758 Touchpad Replacement, DC Jack: step 3, image 1 of 3 Dell Inspiron 5758 Touchpad Replacement, DC Jack: step 3, image 2 of 3 Dell Inspiron 5758 Touchpad Replacement, DC Jack: step 3, image 3 of 3
      • Remove the one 3mm optical drive screw.
      • Remove the two 8 mm screws.
      • Pry up and remove the access door.
      Ask FixBot
    2. Dell Inspiron 5758 Touchpad Replacement: step 4, image 1 of 1
      • Remove the one 3 mm screw.
      • Remove the bracket.
      Ask FixBot
    3. Dell Inspiron 5758 Touchpad Replacement: step 5, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement: step 5, image 2 of 2
      • Unplug the antenna cables.
      • Remove the Wireless Card.
      Ask FixBot
    4. Dell Inspiron 5758 Touchpad Replacement: step 6, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement: step 6, image 2 of 2
      • Unplug the hard drive cable.
      • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
      • Remove the four 8 mm screws.
      • Remove the hard drive.
      Ask FixBot
    5. Dell Inspiron 5758 Touchpad Replacement: step 7, image 1 of 3 Dell Inspiron 5758 Touchpad Replacement: step 7, image 2 of 3 Dell Inspiron 5758 Touchpad Replacement: step 7, image 3 of 3
      • Remove the two 3 mm screws under the battery.
      • Remove the three 2 mm wafer screws under the optical drive.
      • Remove the ten 8 mm base screws.
      Ask FixBot
    6. Dell Inspiron 5758 Touchpad Replacement: step 8, image 1 of 1
      • Unplug the speaker cable by sliding to the right.
      Ask FixBot
    7. Dell Inspiron 5758 Touchpad Replacement: step 9, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement: step 9, image 2 of 2
      • Press in the tabs to loosen the keyboard.
      • Carefully lift the keyboard up and turn it over.
      Ask FixBot
    8. Dell Inspiron 5758 Touchpad Replacement: step 10, image 1 of 1
      • Unplug the keyboard cable & remove the keyboard.
      Ask FixBot
    9. Dell Inspiron 5758 Touchpad Replacement: step 11, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement: step 11, image 2 of 2
      • Slide the DVD optical drive over & remove it from the laptop.
      Ask FixBot
    10. Dell Inspiron 5758 Touchpad Replacement: step 12, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement: step 12, image 2 of 2
      • Remove the four 5 mm screws.
      • Unplug the optical drive interposer cable.
      Ask FixBot
    11. Dell Inspiron 5758 Touchpad Replacement: step 13, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement: step 13, image 2 of 2
      • Unplug the power button cable.
      • Unplug the touchpad cable.
      Ask FixBot
    12. Dell Inspiron 5758 Touchpad Replacement: step 14, image 1 of 3 Dell Inspiron 5758 Touchpad Replacement: step 14, image 2 of 3 Dell Inspiron 5758 Touchpad Replacement: step 14, image 3 of 3
      • Carefully pry off & loosen the bottom base.
      Ask FixBot
    13. Dell Inspiron 5758 Touchpad Replacement: step 15, image 1 of 1
      • Remove the bottom base.
      Ask FixBot
    14. Dell Inspiron 5758 Touchpad Replacement: step 16, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement: step 16, image 2 of 2
      • Remove the one 5mm screw.
      • Lift the circuit board & turn it over.
      • Unplug the cable.
      • Remove the audio/USB circuit board.
      Ask FixBot
    15. Dell Inspiron 5758 Touchpad Replacement: step 17, image 1 of 3 Dell Inspiron 5758 Touchpad Replacement: step 17, image 2 of 3 Dell Inspiron 5758 Touchpad Replacement: step 17, image 3 of 3
      • Loosen the audio / USB cable.
      • Remove the one 3mm motherboard screw.
      • Lift the motherboard & carefully move it out of the way.
      Ask FixBot
    16. Dell Inspiron 5758 Touchpad Replacement: step 18, image 1 of 3 Dell Inspiron 5758 Touchpad Replacement: step 18, image 2 of 3 Dell Inspiron 5758 Touchpad Replacement: step 18, image 3 of 3
      • Unplug the DC jack cable.
      • Remove the one 3mm screw.
      • Remove the DC Jack.
      Ask FixBot
    1. Dell Inspiron 5758 Touchpad Replacement, Touchpad: step 19, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement, Touchpad: step 19, image 2 of 2
      • Release the antenna cable tape.
      • Release the antenna cables.
      Ask FixBot
    2. Dell Inspiron 5758 Touchpad Replacement: step 20, image 1 of 3 Dell Inspiron 5758 Touchpad Replacement: step 20, image 2 of 3 Dell Inspiron 5758 Touchpad Replacement: step 20, image 3 of 3
      • Remove the four 5mm right hinge screws using the Phillips #00 screwdriver.
      • Remove the three 5mm left hinge screws using Phillips #00 screwdriver.
      • Open the hinges carefully and remove the LCD display assembly.
      Ask FixBot
    3. Dell Inspiron 5758 Touchpad Replacement: step 21, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement: step 21, image 2 of 2
      • Remove the one 2mm wafer screw using Phillips #0 screwdriver.
      • Loosen the cable and remove the power button circuit board.
      Ask FixBot
    4. Dell Inspiron 5758 Touchpad Replacement: step 22, image 1 of 2 Dell Inspiron 5758 Touchpad Replacement: step 22, image 2 of 2
      • Push up on the touchpad to release it from the housing.
      • Remove the touchpad.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 68
All Time: 1,059
