Dell Inspiron 5758 LCD Screen Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
69
All Time:
1,289
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the LCD Screen on the Dell Inspiron 5758.
Prerequisite guides are:
  • Battery
  • Hard Drive
  • DC Jack
  • Keyboard
Parts
Tools
    1. Dell Inspiron 5758 LCD Screen Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
      Ask FixBot
    2. Dell Inspiron 5758 LCD Screen Replacement: step 2, image 1 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 2, image 2 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 2, image 3 of 3
      • Slide the battery release switch towards the unlock icon.
      • You should hear a click.
      • Lift and pull the ejected battery to remove it.
      Ask FixBot
    1. Dell Inspiron 5758 LCD Screen Replacement, DC Jack: step 3, image 1 of 3 Dell Inspiron 5758 LCD Screen Replacement, DC Jack: step 3, image 2 of 3 Dell Inspiron 5758 LCD Screen Replacement, DC Jack: step 3, image 3 of 3
      • Remove the one 3mm optical drive screw.
      • Remove the two 8 mm screws.
      • Pry up and remove the access door.
      Ask FixBot
    2. Dell Inspiron 5758 LCD Screen Replacement: step 4, image 1 of 1
      • Remove the one 3 mm screw.
      • Remove the bracket.
      Ask FixBot
    3. Dell Inspiron 5758 LCD Screen Replacement: step 5, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 5, image 2 of 2
      • Unplug the antenna cables.
      • Remove the Wireless Card.
      Ask FixBot
    4. Dell Inspiron 5758 LCD Screen Replacement: step 6, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 6, image 2 of 2
      • Unplug the hard drive cable.
      • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
      • Remove the four 8 mm screws.
      • Remove the hard drive.
      Ask FixBot
    5. Dell Inspiron 5758 LCD Screen Replacement: step 7, image 1 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 7, image 2 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 7, image 3 of 3
      • Remove the two 3 mm screws under the battery.
      • Remove the three 2 mm wafer screws under the optical drive.
      • Remove the ten 8 mm base screws.
      Ask FixBot
    6. Dell Inspiron 5758 LCD Screen Replacement: step 8, image 1 of 1
      • Unplug the speaker cable by sliding to the right.
      Ask FixBot
    7. Dell Inspiron 5758 LCD Screen Replacement: step 9, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 9, image 2 of 2
      • Press in the tabs to loosen the keyboard.
      • Carefully lift the keyboard up and turn it over.
      Ask FixBot
    8. Dell Inspiron 5758 LCD Screen Replacement: step 10, image 1 of 1
      • Unplug the keyboard cable & remove the keyboard.
      Ask FixBot
    9. Dell Inspiron 5758 LCD Screen Replacement: step 11, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 11, image 2 of 2
      • Slide the DVD optical drive over & remove it from the laptop.
      Ask FixBot
    10. Dell Inspiron 5758 LCD Screen Replacement: step 12, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 12, image 2 of 2
      • Remove the four 5 mm screws.
      • Unplug the optical drive interposer cable.
      Ask FixBot
    11. Dell Inspiron 5758 LCD Screen Replacement: step 13, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 13, image 2 of 2
      • Unplug the power button cable.
      • Unplug the touchpad cable.
      Ask FixBot
    12. Dell Inspiron 5758 LCD Screen Replacement: step 14, image 1 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 14, image 2 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 14, image 3 of 3
      • Carefully pry off & loosen the bottom base.
      Ask FixBot
    13. Dell Inspiron 5758 LCD Screen Replacement: step 15, image 1 of 1
      • Remove the bottom base.
      Ask FixBot
    14. Dell Inspiron 5758 LCD Screen Replacement: step 16, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 16, image 2 of 2
      • Remove the one 5mm screw.
      • Lift the circuit board & turn it over.
      • Unplug the cable.
      • Remove the audio/USB circuit board.
      Ask FixBot
    15. Dell Inspiron 5758 LCD Screen Replacement: step 17, image 1 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 17, image 2 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 17, image 3 of 3
      • Loosen the audio / USB cable.
      • Remove the one 3mm motherboard screw.
      • Lift the motherboard & carefully move it out of the way.
      Ask FixBot
    16. Dell Inspiron 5758 LCD Screen Replacement: step 18, image 1 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 18, image 2 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 18, image 3 of 3
      • Unplug the DC jack cable.
      • Remove the one 3mm screw.
      • Remove the DC Jack.
      Ask FixBot
    1. Dell Inspiron 5758 LCD Screen Replacement, Touchpad: step 19, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement, Touchpad: step 19, image 2 of 2
      • Release the antenna cable tape.
      • Release the antenna cables.
      Ask FixBot
    2. Dell Inspiron 5758 LCD Screen Replacement: step 20, image 1 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 20, image 2 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 20, image 3 of 3
      • Remove the four 5mm right hinge screws using the Phillips #00 screwdriver.
      • Remove the three 5mm left hinge screws using Phillips #00 screwdriver.
      • Open the hinges carefully and remove the LCD display assembly.
      Ask FixBot
    3. Dell Inspiron 5758 LCD Screen Replacement: step 21, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 21, image 2 of 2
      • Remove the one 2mm wafer screw using Phillips #0 screwdriver.
      • Loosen the cable and remove the power button circuit board.
      Ask FixBot
    4. Dell Inspiron 5758 LCD Screen Replacement: step 22, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 22, image 2 of 2
      • Push up on the touchpad to release it from the housing.
      • Remove the touchpad.
      Ask FixBot
    1. Dell Inspiron 5758 LCD Screen Replacement, LCD Screen: step 23, image 1 of 3 Dell Inspiron 5758 LCD Screen Replacement, LCD Screen: step 23, image 2 of 3 Dell Inspiron 5758 LCD Screen Replacement, LCD Screen: step 23, image 3 of 3
      • Once you have removed the LCD display assembly from the palmrest touchpad, use a spudger to unsnap the LCD bezel via the notches on the outside edge of the bezel .
      • The bezel may require some force to unsnap.
      • When you have removed the LCD bezel, place it to the side.
      Ask FixBot
    2. Dell Inspiron 5758 LCD Screen Replacement: step 24, image 1 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 24, image 2 of 3 Dell Inspiron 5758 LCD Screen Replacement: step 24, image 3 of 3
      • Remove the ten 4.5mm screen screws.
      • There is one screw in the top left, one screw in the top right, four in the bottom left, and four in the bottom right.
      Ask FixBot
    3. Dell Inspiron 5758 LCD Screen Replacement: step 25, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 25, image 2 of 2
      • Lift the LCD screen from the display assembly, flip the LCD screen over, and place the screen face down.
      • Unplug the LCD cable.
      • Place the display assembly to the side.
      Ask FixBot
    4. Dell Inspiron 5758 LCD Screen Replacement: step 26, image 1 of 2 Dell Inspiron 5758 LCD Screen Replacement: step 26, image 2 of 2
      • Remove the three 3mm screws that connect each hinge rail to the LCD screen.
      • Remove the hinge rails.
      • There are two hinge rails, one on the left edge of the screen and one on the right edge.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 69
All Time: 1,289
