Dell Inspiron 531 Graphics Card Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
100
All Time:
2,008
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Are you trying to enhance your Dell Inspiron's graphics capabilities? Use this guide to replace your graphics card and let the visual splendor begin.
Tools
    1. Dell Inspiron 531 Graphics Card Replacement, Side Panel: step 1, image 1 of 2 Dell Inspiron 531 Graphics Card Replacement, Side Panel: step 1, image 2 of 2
      • Place the desktop on its side. Make sure to place the computer on a soft but firm surface.
      • Locate and remove the two screws that secure the side panel to the desktop:
      • Two 1/4" Phillips/slotted combination screws.
      Ask FixBot
    2. Dell Inspiron 531 Graphics Card Replacement: step 2, image 1 of 1
      • Slide the side panel towards the back of the desktop in order to remove it.
      Ask FixBot
    3. Dell Inspiron 531 Graphics Card Replacement, Locating the Graphics Card: step 3, image 1 of 2 Dell Inspiron 531 Graphics Card Replacement, Locating the Graphics Card: step 3, image 2 of 2
      • The graphics card is attached to the back of the desktop.
      • The graphics card is located below the three fans.
      Ask FixBot
    4. Dell Inspiron 531 Graphics Card Replacement, Support Bracket: step 4, image 1 of 1
      • Remove the screw that secures the support bracket:
      • One 1/4" Phillips screw
      Ask FixBot
    5. Dell Inspiron 531 Graphics Card Replacement: step 5, image 1 of 2 Dell Inspiron 531 Graphics Card Replacement: step 5, image 2 of 2
      • Remove the support bracket by lifting up and out.
      • There are tabs that hold the bracket in place, therefor lifting up is an important detail.
      Ask FixBot
    6. Dell Inspiron 531 Graphics Card Replacement, Removing the Graphics Card: step 6, image 1 of 2 Dell Inspiron 531 Graphics Card Replacement, Removing the Graphics Card: step 6, image 2 of 2
      • Locate the push tab that locks the graphics card into place.
      • Push the tab away from the graphics card and towards the fan.
      • Hold the tab in this position through step 7.
      Ask FixBot
    7. Dell Inspiron 531 Graphics Card Replacement: step 7, image 1 of 2 Dell Inspiron 531 Graphics Card Replacement: step 7, image 2 of 2
      • Keep the tab pushed away from the graphics card (see Step 6).
      • Gently lift the graphics card up and out of the desktop.
      Ask FixBot
Scott Havard
51,395 Reputation
31 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 100
All Time: 2,008
