Dell Inspiron 5100 PP07L Screen Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
105
All Time:
4,258
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
You will be able to access wires connecting your screen and replace it if needed.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Dell Inspiron 5100 PP07L Screen Replacement, Keyboard: step 1, image 1 of 1
      • Remove battery
      • Open screen so that it lies flat.
      Ask FixBot
    2. Dell Inspiron 5100 PP07L Screen Replacement: step 2, image 1 of 2 Dell Inspiron 5100 PP07L Screen Replacement: step 2, image 2 of 2
      • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
      Ask FixBot
    3. Dell Inspiron 5100 PP07L Screen Replacement: step 3, image 1 of 2 Dell Inspiron 5100 PP07L Screen Replacement: step 3, image 2 of 2
      • Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
      Ask FixBot
    4. Dell Inspiron 5100 PP07L Screen Replacement: step 4, image 1 of 1
      • Lift keyboard and detach the interface connector.
      • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
      Ask FixBot
    1. Dell Inspiron 5100 PP07L Screen Replacement, Screen: step 5, image 1 of 2 Dell Inspiron 5100 PP07L Screen Replacement, Screen: step 5, image 2 of 2
      • Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
      Ask FixBot
    2. Dell Inspiron 5100 PP07L Screen Replacement: step 6, image 1 of 1
      • Detach the screen connector.
      Ask FixBot
    3. Dell Inspiron 5100 PP07L Screen Replacement: step 7, image 1 of 2 Dell Inspiron 5100 PP07L Screen Replacement: step 7, image 2 of 2
      • Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
      Ask FixBot
    4. Dell Inspiron 5100 PP07L Screen Replacement: step 8, image 1 of 1
      • Lift and remove display screen.
      Ask FixBot
May Chauvin
201 Reputation
6 Guides authored
Cal Poly, Team 12-34, Maness Spring 2011 Member of Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 105
All Time: 4,258
