Dell Inspiron 5100 PP07L Memory Replacement
    1. Dell Inspiron 5100 PP07L Memory Replacement, Revealing the memory panel: step 1, image 1 of 1
      • Flip the laptop on it's back, so that the bottom is facing up.
      Ask FixBot
    2. Dell Inspiron 5100 PP07L Memory Replacement, Screw Removal: step 2, image 1 of 1
      • Loosen the single Phillips #1 screw.
      • This screw is attached to the panel and cannot be removed.
      Ask FixBot
    3. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: step 3, image 1 of 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: step 3, image 2 of 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: step 3, image 3 of 3
      • Push the highlighted pin outward until the RAM pops slightly out of its socket.
      • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
      • Not seating the new DIMMs correctly could cause the device to refuse to POST.
      Ask FixBot
2 other people completed this guide.
May Chauvin
201 Reputation
6 Guides authored
Cal Poly, Team 12-34, Maness Spring 2011 Member of Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 107
All Time: 5,104
