Dell Inspiron 3847 RAM Stick Replacement
    1. Dell Inspiron 3847 RAM Stick Replacement, RAM Stick: step 1, image 1 of 1
      • Shut off and power down the PC by turning the switch to the off position, located on the back of the PC.
      • Unplug the power cable and remove any and all peripherals connected to PC.
      Ask FixBot
    2. Dell Inspiron 3847 RAM Stick Replacement: step 2, image 1 of 3 Dell Inspiron 3847 RAM Stick Replacement: step 2, image 2 of 3 Dell Inspiron 3847 RAM Stick Replacement: step 2, image 3 of 3
      • Lay your PC flat on its side with the 'Inspiron' Logo facing up.
      • Remove the two Phillips #0 screws from the back side of panel.
      • Slide the side panel off completely.
      Ask FixBot
    3. Dell Inspiron 3847 RAM Stick Replacement: step 3, image 1 of 2 Dell Inspiron 3847 RAM Stick Replacement: step 3, image 2 of 2
      • Gently press down the flaps located on each end of the RAM slots. Remove the RAM stick(s) from the motherboard.
      • Repeat this step for each stick of RAM.
      • The flaps may be stiff when pressing down. Be careful not to use too much force if the RAM stick doesn't come loose.
      Ask FixBot
    4. Dell Inspiron 3847 RAM Stick Replacement: step 4, image 1 of 3 Dell Inspiron 3847 RAM Stick Replacement: step 4, image 2 of 3 Dell Inspiron 3847 RAM Stick Replacement: step 4, image 3 of 3
      • Align the new memory sticks with the memory slots.
      • Gently press down until a “CLICK” sound is made and flaps are pointing upwards.
      • Repeat this step for each stick of RAM you want to install.
      Ask FixBot
    5. Dell Inspiron 3847 RAM Stick Replacement: step 5, image 1 of 3 Dell Inspiron 3847 RAM Stick Replacement: step 5, image 2 of 3 Dell Inspiron 3847 RAM Stick Replacement: step 5, image 3 of 3
      • Slide the side panel back into position and screw in with the same screws from Step #2.
      • Plug all peripherals into the PC and switch it back on.
      • Boot up the computer. If no errors appear, then installation is complete!
      Ask FixBot
To check if your RAM is installed correctly, Right-click on My PC, Click Properties, and check Installed Memory under the System heading.
Maninder
195 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 97
All Time: 2,005
