Dell Inspiron 3552 Hard Drive Replacement Part 1
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
76
All Time:
1,483
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Community-Contributed Guide
Introduction
Go to step 1 ↓
part 2: Dell Inspiron 3552 Hard drive Replacement part 2 - iFixit Repair Guide
Parts
    1. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the battery: step 1, image 1 of 1
      • Close the display and turn the computer over
      • Slide the battery-release latch to the unlocked position
      • Lift the battery at an angle and remove the battery from the battery bay
      Ask FixBot
    2. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing optical drive: step 2, image 1 of 1
      • Remove the screw that secures the optical-drive assembly to the base cover.
      • Using a plastic scribe, push the optical-drive assembly out of the optical-drive bay.
      • Pull the optical-drive assembly out of the optical-drive bay.
      Ask FixBot
    3. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: step 3, image 1 of 2 Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: step 3, image 2 of 2
      • Turn on the computer over and open the display
      • Using a plastic scribe, gently release the tabs that secure the keyboard to the palm-rest assembly
      • Slide the keyboard up to release it from the slots on the palm-rest assembly.
      • Carefully turn the keyboard over and place it on the palm-rest assembly
      Ask FixBot
    4. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: step 4, image 1 of 3 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: step 4, image 2 of 3 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: step 4, image 3 of 3
      • Open the display and remove the screws that secure the palm-rest assembly to the base cover from its connector on the system board
      • Open the latch and disconnect the optical-drive cable from its connector on the system board
      • Close the display and turn the computer over.
      • Remove the screws that secure the base cover to the palm-rest assembly
      • Using your fingertips, gently pry the base cover off the palm-rest assembly
      Ask FixBot
    5. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing the base part 2: step 5, image 1 of 1
      • Release the optical-drive interposer from the tabs on the base cover.
      Ask FixBot
Jordon Dozier
1,663 Reputation
12 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 76
All Time: 1,483
