Dell Inspiron 3501 Battery Replacement
    1. Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: step 1, image 1 of 2 Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: step 1, image 2 of 2
      • For your safety, discharge the battery below 25% and power down your device before disassembly.
      • Use your Phillips screwdriver to remove the seven screws securing the back cover:
      • Three 5 mm-long screws
      • Four 7.5 mm-long screws
      • Loosen the three captive screws.
      Ask FixBot
    2. Dell Inspiron 3501 Battery Replacement, Unclip the front corners: step 2, image 1 of 2 Dell Inspiron 3501 Battery Replacement, Unclip the front corners: step 2, image 2 of 2
      • Flip the laptop upright and open the lid so that the keyboard is exposed.
      • Insert an opening pick between the front right corner of the back cover and the chassis.
      • Pry upward to release the retaining clips holding the cover.
      • You'll hear clicks whenever a clip is released.
      • Repeat this procedure for the opposite corner.
      Ask FixBot
    3. Dell Inspiron 3501 Battery Replacement, Unclip the front edge: step 3, image 1 of 2 Dell Inspiron 3501 Battery Replacement, Unclip the front edge: step 3, image 2 of 2
      • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
      • Pry upward to release the clips along the front edge of the laptop.
      Ask FixBot
    4. Dell Inspiron 3501 Battery Replacement, Remove the back cover: step 4, image 1 of 3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: step 4, image 2 of 3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: step 4, image 3 of 3
      • Close the screen to the laptop and flip it over.
      • Pull the left side of the back cover away from the frame and remove it.
      • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
      Ask FixBot
    1. Dell Inspiron 3501 Battery Replacement, Disconnect the battery: step 5, image 1 of 2 Dell Inspiron 3501 Battery Replacement, Disconnect the battery: step 5, image 2 of 2
      • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
      Ask FixBot
    1. Dell Inspiron 3501 Battery Replacement, Unfasten the battery: step 6, image 1 of 2 Dell Inspiron 3501 Battery Replacement, Unfasten the battery: step 6, image 2 of 2
      • Use a Phillips screwdriver to remove the three 3.3 mm-long screws securing the battery.
      Ask FixBot
    2. Dell Inspiron 3501 Battery Replacement, Remove the battery: step 7, image 1 of 3 Dell Inspiron 3501 Battery Replacement, Remove the battery: step 7, image 2 of 3 Dell Inspiron 3501 Battery Replacement, Remove the battery: step 7, image 3 of 3
      • Lift the battery straight out of its recess and remove it.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
4 other people completed this guide.
Alex Diaz-Kokaisl
250,475 Reputation
1,201 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,996 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 62
Past 30 Days: 177
All Time: 4,576
