Dell Inspiron 3148 Motherboard Replacement
    1. Dell Inspiron 3148 Motherboard  Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 3148 Motherboard  Replacement, Back Panel: step 1, image 2 of 2
      • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
      • Flip the device over so the backside is facing you.
      Ask FixBot
    2. Dell Inspiron 3148 Motherboard  Replacement: step 2, image 1 of 1
      • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
      Ask FixBot
    3. Dell Inspiron 3148 Motherboard  Replacement: step 3, image 1 of 2 Dell Inspiron 3148 Motherboard  Replacement: step 3, image 2 of 2
      • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
      • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
      Ask FixBot
    1. Dell Inspiron 3148 Motherboard  Replacement, Battery: step 4, image 1 of 1
      • Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Inspiron 3148 Motherboard  Replacement: step 5, image 1 of 1
      • Using the iFixit opening tools, lift the battery out of its housing.
      Ask FixBot
    3. Dell Inspiron 3148 Motherboard  Replacement: step 6, image 1 of 1
      • Once loosened, use your fingers to lift the battery up and out of its housing.
      • There is a small cable which sits in a rut in the top of the battery. Ensure that it is pushed out of the way before removing completely.
      Ask FixBot
    4. Dell Inspiron 3148 Motherboard  Replacement: step 7, image 1 of 1
      • Remove the battery completely.
      Ask FixBot
    1. Dell Inspiron 3148 Motherboard  Replacement, Hard Drive: step 8, image 1 of 3 Dell Inspiron 3148 Motherboard  Replacement, Hard Drive: step 8, image 2 of 3 Dell Inspiron 3148 Motherboard  Replacement, Hard Drive: step 8, image 3 of 3
      • If there is a piece of tape connecting the hard drive and a small power cord, remove the tape.
      • Using the Phillips #0 screwdriver, remove the two 4mm screws.
      Ask FixBot
    2. Dell Inspiron 3148 Motherboard  Replacement: step 9, image 1 of 3 Dell Inspiron 3148 Motherboard  Replacement: step 9, image 2 of 3 Dell Inspiron 3148 Motherboard  Replacement: step 9, image 3 of 3
      • Notice: there is a small data cable connecting the hard drive to the motherboard. Do not attempt to lift the hard drive all the way out before removing this cable.
      • Lift the hard drive slightly out of the device.
      • Grasp the head of the cable, not the cable itself.
      • Pull away from the hard drive, removing the data cable. The hard drive may now be fully removed.
      Ask FixBot
    1. Dell Inspiron 3148 Motherboard  Replacement, Fan: step 10, image 1 of 3 Dell Inspiron 3148 Motherboard  Replacement, Fan: step 10, image 2 of 3 Dell Inspiron 3148 Motherboard  Replacement, Fan: step 10, image 3 of 3
      • If there is tape on your fan, remove the tape.
      • Remove the two 2mm screws on the fan enclosure using the Phillips #00 screwdriver.
      Ask FixBot
    2. Dell Inspiron 3148 Motherboard  Replacement: step 11, image 1 of 2 Dell Inspiron 3148 Motherboard  Replacement: step 11, image 2 of 2
      • Unscrew the three 4mm screws holding down the heat sink of the fan using the Phillips #00 screwdriver.
      • The three 4mm screws found in the heat sink will remain attached to the heat sink. This is okay as long as they are detached from the motherboard.
      Ask FixBot
    3. Dell Inspiron 3148 Motherboard  Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to gently pull the power supply cable from its port.
      Ask FixBot
    4. Dell Inspiron 3148 Motherboard  Replacement: step 13, image 1 of 1
      • Grasp the fan and lift upward. Remove the fan from the device.
      Ask FixBot
    1. Dell Inspiron 3148 Motherboard  Replacement, Motherboard: step 14, image 1 of 1
      • Remove the keyboard cable from its ZIF connector by flipping up the locking tab on the connector and then pulling the cable out.
      Ask FixBot
    2. Dell Inspiron 3148 Motherboard  Replacement: step 15, image 1 of 1
      • Remove the touch pad cable from its ZIF connector.
      Ask FixBot
    3. Dell Inspiron 3148 Motherboard  Replacement: step 16, image 1 of 1
      • Remove one 3.41mm screw using a Phillips #000 screwdriver.
      • Remove the two 3.41mm screws using a Phillips #000 screwdriver.
      • Remove motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 68
All Time: 414
