Dell Inspiron 17R-N7110 RAM Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
72
All Time:
1,789
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk you through removing and replacing your Dell Inspiron 17R-N7110 RAM stick(s). You will be handling delicate electronic components during this process, so be sure to wear the anti-static wrist strap for this replacement.
Tools
    1. Dell Inspiron 17R-N7110 RAM Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 17R-N7110 RAM Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 17R-N7110 RAM Replacement, Battery: step 1, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components.
      • Place the laptop on a flat surface with the Dell logo upside down.
      • Flip the laptop over. The battery will be in the top center.
      Ask FixBot
    2. Dell Inspiron 17R-N7110 RAM Replacement: step 2, image 1 of 2 Dell Inspiron 17R-N7110 RAM Replacement: step 2, image 2 of 2
      • Slide both the left lock and right lock, towards the center of the battery.
      • Push upwards on the grip on the bottom of the battery to remove it.
      Ask FixBot
    1. Dell Inspiron 17R-N7110 RAM Replacement, RAM: step 3, image 1 of 2 Dell Inspiron 17R-N7110 RAM Replacement, RAM: step 3, image 2 of 2
      • Using a Phillips #1 screwdriver, unscrew the .7mm screw at the top of the RAM compartment as pictured.
      • Use a metal Jimmy to pry open the RAM cover from the top of the compartment.
      Ask FixBot
    2. Dell Inspiron 17R-N7110 RAM Replacement: step 4, image 1 of 3 Dell Inspiron 17R-N7110 RAM Replacement: step 4, image 2 of 3 Dell Inspiron 17R-N7110 RAM Replacement: step 4, image 3 of 3
      $7.95
      Buy
      • Do not touch the RAM sticks without releasing static electricity build up. Make sure you are wearing the anti-static wrist strap, and that the metal clip is attached to a grounded metal object.
      • There are two small plastic prongs to the sides of the first RAM stick. Push the prongs away from each other to release the RAM stick.
      • Gently remove the RAM stick.
      • If your laptop has a second RAM stick located underneath the first one, repeat this step to remove it.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 72
All Time: 1,789
