Dell Inspiron 17R-N7110 Keyboard Replacement
    1. Dell Inspiron 17R-N7110 Keyboard Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 17R-N7110 Keyboard Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 17R-N7110 Keyboard Replacement, Battery: step 1, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components.
      • Place the laptop on a flat surface with the Dell logo upside down.
      • Flip the laptop over. The battery will be in the top center.
      Ask FixBot
    2. Dell Inspiron 17R-N7110 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 17R-N7110 Keyboard Replacement: step 2, image 2 of 2
      • Slide both the left lock and right lock, towards the center of the battery.
      • Push upwards on the grip on the bottom of the battery to remove it.
      Ask FixBot
    1. Dell Inspiron 17R-N7110 Keyboard Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 17R-N7110 Keyboard Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 17R-N7110 Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Do not pull the keyboard away from the laptop. The keyboard is connected to the motherboard by a cable. Pulling the keyboard may cause damage to the keyboard and/or motherboard.
      • Metal spudgers and similar prying tools can damage internal components like the motherboard. It is ideal to use a regular black nylon spudger or a plastic opening tool, but for this device the metal jimmy was the only tool to work.
      • Flip over and open your device. Gently wedge the metal Jimmy into the rightmost hole at a 45-degree angle. Make sure that the Jimmy is between the silver metal portion of the keyboard and the silver plastic edge around the keyboard.
      • Tilt the metal jimmy away from you to pry up the edge of the keyboard.
      • Repeat the previous actions on each of the other three holes to release the keyboard.
      Ask FixBot
    2. Dell Inspiron 17R-N7110 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 17R-N7110 Keyboard Replacement: step 4, image 2 of 2
      • Gently flip the keyboard over and lay it on the touchpad area.
      Ask FixBot
    3. Dell Inspiron 17R-N7110 Keyboard Replacement: step 5, image 1 of 3 Dell Inspiron 17R-N7110 Keyboard Replacement: step 5, image 2 of 3 Dell Inspiron 17R-N7110 Keyboard Replacement: step 5, image 3 of 3
      • Flip up the black flap where the keyboard cable connects to the motherboard
      • Gently pull the cable away from the slot to release the keyboard.
      • Remove the keyboard from the device.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 46
All Time: 2,221
